The Do and Do not in a alky injection system
Old Jan 14, 2008 | 08:48 PM
  #31
Richard L's Avatar
Originally Posted by joah1660
So then I'm not getting "full boost" since my B is not coming on? How do I make it so my B comes on during a run? I assume I just have to adjust my "set" window.
First of all, adjust your bargraph reading to about ~6 bars at full boost (SC), Then adjust the WL and WH until the "B" led lights up during the spray range.
Start the WL from 6 clicks form full counter-clockwise.
Then adjust the WH from fully clockwise. Once this is done, adjust each trimmer back 1 to 2 clicks back.
Are you using the failsafe output to cut boost or switch map?
Old Jan 14, 2008 | 08:58 PM
  #32
SlowCar's Avatar
Originally Posted by Richard L
One more.. abner,
Don't use contaminated methanol.
Check it for clarity with water.
updated
Old Jan 14, 2008 | 09:05 PM
  #33
Evoryder's Avatar
Originally Posted by LilRico
Great video! Makes me wonder how my Snow kit is performing when it shuts off... Does it leak like that... Hmmm...
probably does. They do offer a solenoid valve.
Old Jan 14, 2008 | 09:22 PM
  #34
SlowCar's Avatar
solenoid valves is not going to work if he is running a variable speed/pressure progressive system...
Old Jan 14, 2008 | 09:32 PM
  #35
Evoryder's Avatar
it's an off or snow pump....unless he's using the stage 2
Old Jan 15, 2008 | 05:33 AM
  #36
LilRico's Avatar
I do believe it is a stage 2. I know it turns on at a certain PSI also.
Old Jan 15, 2008 | 07:53 AM
  #37
joah1660's Avatar
Thanks for the info Richard. I will try this adjustment in the next couple of days.
I do have a failsafe solenoid. Will this mater when setting these adjustments?
Old Jan 16, 2008 | 01:54 PM
  #38
joah1660's Avatar
bump 4 Richard (or anyone who can answer it)...
