Another Aquamist install in Tucson!!!PICS
Old Jan 22, 2008 | 09:44 PM
esevo's Avatar
I helped my best friend Rick here in Tucson AZ by installing his kit for him then tuning it.
The kit is Aquamist HFS-5 with two 1mm nozzels running 50/50 water meth. The tank is a JDM STI water intercooler sprayer 12L(4 gallon) tank. With priming pump and low level switch. = A LOT OF METH!!!
The tank location is the best part it is easy to fill, still leaving plenty of room and it still has room for a strut bar and spare tire!!
The tune; The car hit 12.0 AFRS, 5 degrees timing at peak tq, Boost at 1.75 bar NO knock! This car moves!!!
MODS: TBE, BC, METH, BOV.
More pics of the car (inside and out) here;
https://www.evolutionm.net/forums/sh...=319599&page=1
Enjoy!!!
Old Jan 23, 2008 | 04:34 AM
EvilBlueEvo8's Avatar
i like that tank. is that really 4 gallons? doesn't look it. i got a 2.5 gallon waiting to go in and its looks a hell of a lot bigger than that one.
Old Jan 23, 2008 | 04:51 AM
Guz Man's Avatar
dude.. thats a huge tank.. very nice..
Old Jan 23, 2008 | 06:44 AM
SlowCar's Avatar
Nice install Evan!
Old Jan 23, 2008 | 07:17 AM
KevinD's Avatar
(2) 1.mm nozzles of meth/water and your only running 25 psi of boost? TURN THE BOOST UP :P
seriously though, i just did another tune on an HFS-5 equipped car with an evo green. 30 psi with a .8mm nozzle and a .9mm nozzle 100% meth. you can definitely run more then 25psi on stock turbo with that much meth. i did that with 100% water and pump gas.
Old Jan 23, 2008 | 07:54 AM
esevo's Avatar
Im sure we could... in fact I KNOW we could lol this is what he wanted for now untill more supporting mods (lower ic pipe, intake, 02 housing ect. ect.) :-)
Old Jan 23, 2008 | 08:28 AM
Richard L's Avatar
very nice install!
Question, you have cut off terminal on the red cable, did you have problem mating it with the HFS-5 harness?
Old Jan 23, 2008 | 08:57 AM
EVO MR's Avatar
Wow, very clean install. Great job
Old Jan 23, 2008 | 10:29 AM
esevo's Avatar
Thank you guys! Richard- Not one problem :-) It was fine, I just wanted to solder everything for reliability plus it made the cable smaller so it was easy to hide ;-). I have had bad luck with bud connections in the past. This kit was a breeze compared to my 2d!
Old Jan 25, 2008 | 11:40 AM
Richard L's Avatar
Thank you. I understand.
When you clean the gauge face, use very soft fabric with some diluted mathanol or the surface will be scratched.
Old Jan 27, 2008 | 12:38 PM
vroomevo's Avatar
saw this in person, very nice install.
cool Evan!!
Old Jan 27, 2008 | 12:46 PM
Slick-IX's Avatar
wow it looks rly nice dude, i like the setup...
Old Feb 7, 2008 | 10:58 PM
thatguy's Avatar
what were the results? I'm thinking about doing something similiar.
Saiko Jon
Apr 24, 2019 12:29 PM
marksae
91
Apr 23, 2018 07:48 AM
krackerstache
Evo X How Tos / Installations
28
Feb 2, 2015 11:49 PM
-Evo Aaron-
Oct 8, 2010 12:04 AM
