Labonte Meth Kit
#93
regarding the LEDs. I originally purchased a snow performance kit which ofcourse comes with a green LED to indicate when the pump is working. Recently, my LED stopped working and I was under the impression that my pump wasn't coming on; after lots of testing and checking, it turns out my LED died on me but everything else was fine.
Here's the interesting part; I went to Frys Electronics to purchase an identical LED and wired it in when I got back home. I soon found out that the new LED also burned out. After paying close attention to the instructions on the back of the LEDs package, I noticed you need to install a 1/2watt 680ohm resistor in order to use the LED with 12 volts. After I discovered this, I checked the LED for my low level indicator and found out it was also burned out. I picked up a second LED (different color) and did the same process of installing a resistor. Now both my LEDs work and no longer have burned LEDs. I hope this helps others; I will post a pic of the style of LEDs I'm using, some LEDs include inline resistors, you just need to make sure they are compatible with 12volts.
Anyone else encounter this problem?
#94
if you want to be really technical with an LED do the following.
all LED's will be safe and bright if running on 20mA of current.
to calculate the resister needed ,
I=V(source)-V(led)/ resistor
so, resistor needed=Battery-LED / 20
usually and LED voltage drop is around 0.7V-1.2V, but can be 3Volts for high intensity LED's.
#97
How many people are running the vc-25, ifs-10 and bbk-10 without running the fcs-10 solenoid? The kit was reinstalled today with the use of it and so far the kit has been working. I know someone had talked about the pooling of meth in the intercooler without. Has anyone experienced this? My tanks is located in the excess resevoir space in the rear-left of the trunk so it is sitting lower than the ifs-10 and the uicp where the meth is tapped.
Last edited by tweaker41; Jun 14, 2009 at 06:17 PM. Reason: Found one of the answers
#101
I was talking with some other people and they have the yellow wire from the VC-25 harness connected to the FCS-10 solenoid. My yellow wire is connected to my MAF as my diagram states. Where's yours running to?
#103
The connection of the yellow wire will depend on what controller you have.
Older versions of the VC-25 used the yellow wire as an injection disable option - pull the wire to ground by a switch to disable injection.
The VC-25D was a special version of the VC-25 made for Mitsu engine to take advantage of the MAF signal for fast spooling turbos. The yellow wire of the VC-25D did connect to the MAF sensor output wire.
New versions of the VC-25 now have a seconday +12v output signal designed to activate the Fluid Control Solenoid. This signal is a constant 12V during injection and is not PWM like the pump signal. This output can also be used to drive a NOS relay or the IFS-10 injection failsafe.
#104
Thanks for the reply. I have another question. I've heard of people having issues with running the IFS-10 into the UICP w/o utilizing the FCS such as gravity feeding methanol into the intercooler. Should I take the time to install it or just leave it as is?
Nadaevo
Feb 17, 2017 01:48 PM
