Hp Estimate?
Old May 15, 2008 | 02:04 PM
paintballproam's Avatar
Hp Estimate?
Evo 8
MODS
Aquamist HFS-1
Turbotrix bb50trim kit .63 a\r w/ TiaL 44mm external Wastegate
Turbotrix custom downpipe
Turbotrix custom lower IC pipe
Custom upper IC pipe
custom made intake
Megan Cat back exhaust
Weapon R oil catchcan
denso 720cc injectors
walbro 255lph pump
Hks 272/264 cams
AEM Tru boost
AEM UEGO widband
New OEM headgasket
ARP Headstuds
Exedy twin disc.
What do you think i should make for power on pump gas, and a 50/50 mix of meth/water?
Just curious
Old May 15, 2008 | 09:15 PM
dudical26's Avatar
Thats pretty tuff to guess maybe 430 WHP on a dynojet.
Old May 15, 2008 | 09:19 PM
wizzo 8's Avatar
400-450WHP on dynojet
Old May 18, 2008 | 11:23 AM
wesside's Avatar
I'm probably guessing about 450 too but if you were to run 100% meth and run some high boost & get agressive with the tune I don't see why you wouldn't be 500 ?
Old May 19, 2008 | 05:16 PM
esevo's Avatar
http://www.dataloglab.com/
^^^ Download this for free and enter the correct info with weight and tires sizes. Select SAE correction and it should get you within 20 whp of a mustang dyno every time!
You baisicaly load a log from evoscan and it estimates your power.
For my guess 380 mustang 20-24psi... 25-30 psi 415 whp mustang (the true dyno)
Old May 19, 2008 | 07:38 PM
wizzo 8's Avatar
link doesnt work
Old May 19, 2008 | 08:13 PM
esevo's Avatar
Odd it works for me... try google (data log lab) it should come up.
Old May 19, 2008 | 09:09 PM
AcePitcher11's Avatar
im guessing 400s also....you have a pretty nice setup
Old May 20, 2008 | 07:46 AM
Ok it wont read my evo scan logs.....
Old May 20, 2008 | 08:09 AM
anjapower's Avatar
A well setup 50 trim on meth should do 450+ whp on a dynojet.
Old May 20, 2008 | 08:13 AM
Evoryder's Avatar
depends on how aggressive you get w/ air fuel and timing.
eg boost 30psi
mid 11 a/f = 420-430whp
low-mid 12 a/f = 460whp(+/- 10)
low 13 a/f (ultra aggressive) = 500whp (+/- 10)
Old May 20, 2008 | 11:31 AM
esevo's Avatar
Make sure you are logging injector pulse width or something like that or it wont read the logs... Tons of tuners use this here on evom so I know it works! GL!
