ok, help me pick...
Old Jun 28, 2008 | 09:35 PM
1mbrews8's Avatar
ok, help me pick...
i have a ets 61mm (gt35) turbo kit with all the usual stuff. i was thinking of adding meth when i get all of it installed. i have a aem ems with uego. which kit is best for use with the aem, and is the ems a good failsafe if i have them set it up that way? i was looking at the smc..or auquamist($)...i also live real close to coolingmist i ga so they would be easy to deal with. i want safety, but i won't be ragging it out all the time. would love to run denatured alcohol cus it's cheap (i heard is almost as good?) help!
Old Jun 29, 2008 | 02:06 AM
Richard L's Avatar
The Aquamist HFS-1 is very reasonable priced (MRRP ~$650) when you consider the completeness of entire package. Except of the water tank (~$15), you have everything there.
Essential items includes:
- 150W pump pulseless pump (internal by-pass)
- 52mm dash gauge monitoring water flow and tank level
- Hi-speed Digital gear-wheel flow sensor
- Failsafe boost control and tephra's "alt-map" patch interface output
- 40A Power relay to create your own switched 12v supply
- Simple upgrade path to HFS-5
Useful links:
https://www.evolutionm.net/forums/sh...ighlight=HFS-1 (user)
https://www.evolutionm.net/forums/sh...ighlight=HFS-1 (tuner)
Old Jun 29, 2008 | 04:27 AM
1mbrews8's Avatar
cool, i was thinking about doing it under the hood, and not the trunk. do i need a specific kit for that?
Old Jun 29, 2008 | 04:59 AM
Richard L's Avatar
There is no reason why the HFS-xx pump can't be mounted in the engine bay. We have other systems but knowing what the EVO is capable of in terms of power, it is always nice "not" to limit yourself to a lower flow Aquamist system.
Old Jun 29, 2008 | 05:20 AM
1mbrews8's Avatar
got ya, could you pm me a quote for whatever i'd need? also is it ok and a good idea to run denatured alcohol? i am pming you a letter if you are interested as well. i can get you pics if you need them too. thanks for the quick reply
Old Jun 29, 2008 | 10:48 AM
Boricua_Evo's Avatar
I bought the Aquamist HSF-1 brand new for 590 shipped. I also bought my tank at United States Plastic Corp. for about $10.
I went this route after researching for about a month on what to buy, the Aquamist was the best bet for me and not to mention the cool looking gauge that's also included. I think about my engine and the capabilities that the aquamist has in protecting your engine while keeping you aware of malfunction possibilities.
Just look around especially in this Forum
All in all, Good luck!
