One Big Nozzle or Two Smaller?
Old Jul 2, 2008 | 09:33 PM
Evoryder's Avatar
I am looking for feed back on revising my setup. Currently have 2 nozzles. 625ml/min x1 right before Throttle body and a 225ml/min nozzle right after the cold side intercooler tank. I only have the 625ml/min currently active, disabled the 225ml/mintoo much fuel)
Was thinking of acquiring a smaller 325ml/minin place of the 625ml/min and bring the 225ml/min more upstream for better tuning and more power. I was also considering a 325ml/min/175ml/min combo, not trying to flood the system.
So. 2 medium size nozzles or 1 big one? ANd how far between the 2 nozzles for optimum stream pattern. I was thinking between 1' -2' between nozzles.
Thanks
Old Jul 3, 2008 | 09:04 AM
cpoevo's Avatar
2 smaller nozzles should work better because you will get better atomization of the alky/water. The bigger the nozzle the larger the spray droplets will be. This is all theory by the way.
Old Jul 3, 2008 | 07:42 PM
Evoryder's Avatar
Thanks for the input. I was leaning towards two nozzles also. I am probably gonna space them a 1' apart as planned.
