Meth still spraying on lift??
Mine did pretty much the same thing, I found a microscopic pin hole in the meth line between the tank and the failsafe. Your situation may be plug related.. How old are yours?
You running 100% or 50/50?
I installed mine myself. I'm pretty mechanically inclined and everyone wanted too much or doesnt do meth kits by me.
Something is up with your kit, run around with your car and then check quickly where all of your lines run to see if you are leaking anywhere before it evaporates
my kit is 2 months old... i am usin 100%
i jsut switched my plugs to denso ikh24s on tuesday. and i have checked all over and no leaks
i also replaced all the lines recently because i had a crack in 1
ha ha!
i checked it and it sprays as soon as it touches the connector and alot! so i think its purged. there like no wait time its instant spray...
i tapped the UICP about 3 inches below the coupler that attaches to the throttle body...
me and 4WS did some logs today and it runs like a champ with out the failsafe... i just want to be able to use it like its supposed to.. thats why i bought it... im just gettin aggravated with it.
i dont like the thought of it either but with the failsafe ****in up i have to send it out to dan again to get it looked at. i pretty much stay outta boost with it unplugged i just want to know why im havin such a hard time with this piece
