Meth still spraying on lift??
Old Jul 12, 2008 | 10:44 AM
06MRV8Killer's Avatar
Meth still spraying on lift?? HELP!
I dont know what the heck is going on with my kit.
My boost hasnt been hitting what it was tuned for, so I figured it out that I had a small pin hole leak in my line between the tank and the failsafe, hence running wastegate.
Fixed that and took it for a spin and now when i lift to shift the car just wants to die....?
When I lift completely and coast I get 8-9's on my afr and it sounds like I have a gigantic cam in and takes about 3 minutes for the car to correct itself. When it corrects itself and I tap the gas it wants to stall again. When it completely corrects itself I can drive normaly without boost but the second I boost the same $&*T keeps happening. I'm so pissed right now.
Seems like when I lift the meth just keeps on spraying and flooding the motor.
I did 3 pulls in 4th to redline and burnt up 1/2 gallon of meth, WTF!?
I cant figure it out for the life of me anyone got any ideas?
Old Jul 12, 2008 | 11:16 AM
Anyone?
Old Jul 12, 2008 | 12:48 PM
I just checked the hell out of everything, No leaks, tested to see if it was spraying and it is, ran down the road w/o meth in the tank and its running on wastegate like it is supposed to.... Any ideas anyone, i know someone at least has to have some guesses that I maybe over looked....
Old Jul 12, 2008 | 11:40 PM
codean's Avatar
How are you checking that your nozzle is spraying ok and the system is working properly?
It sounds like your alcohol injection kit isn't shutting off when you lift, or you over spraying and alcohol is pooling up.
Old Jul 13, 2008 | 06:30 AM
Thats exactly what it seems like.... I test it by letting it idle and switching the connection that is meant to test the system. I am going to get on it today and figure it out I hope.
Anyone got any more ideas or experience this?
Old Jul 13, 2008 | 08:15 AM
ddillard424's Avatar
are you using the fuel controll solenoid or just using the pump to failsafe to nozzle??
Old Jul 13, 2008 | 11:32 AM
Yes i have one
Old Jul 13, 2008 | 02:58 PM
i wonder if the FCS is staying open or not closing when you get off boost...
Old Jul 13, 2008 | 03:03 PM
4WS Tuning's Avatar
Problem solved =-) The line wasn't properly purged! Pulling like a **** again!
Old Jul 14, 2008 | 05:15 PM
Nice! glad to here its back in business!!
Old Jul 15, 2008 | 07:13 PM
Yeah thankfully it wasnt anything major.
Old Jul 16, 2008 | 08:00 PM
my kits acting up AGAIN!!!! i dont know what the hell is wrong with it. with the fail safe plugged in its running super rich in 3rd and bogs down in 4th and stutters to hell and now is throwing me to wastegate pressure. there is no kinks or holes in line... im using M12 nozzle and trip point is set at 308mL/Min. when i take power away from the failsafe the car runs great... i dont know what is wrong... dan at labonte looked at the failsafe last week and said it was good... it worked for a few days and then started to do this crap again...
Old Jul 16, 2008 | 08:38 PM
TTP Engineering's Avatar
Where are all these kits being installed?
Old Jul 17, 2008 | 03:07 PM
i installed my kit myself. it was a basic install, no where near as complicated as the aquamist looks... but i dont hear of anyproblems with those...
Old Jul 17, 2008 | 03:20 PM
Mine did pretty much the same thing, I found a microscopic pin hole in the meth line between the tank and the failsafe. Your situation may be plug related.. How old are yours?
You running 100% or 50/50?
I installed mine myself. I'm pretty mechanically inclined and everyone wanted too much or doesnt do meth kits by me.
Something is up with your kit, run around with your car and then check quickly where all of your lines run to see if you are leaking anywhere before it evaporates
