Snow Kit install
Old Aug 13, 2008 | 12:31 PM
TKEVO's Avatar
Veteran: Air Force
Looks good. I know what to look for. How much Alky do you go through in 1 tank? how often you have to refill? When is yours setup to activate?(Boost)
Old Aug 13, 2008 | 06:56 PM
bhood1's Avatar
I usually have to fill the alky tank up every 3 to 4 tanks of gas......depending on how heavy my foot is. I set me boost up to activate at 8psi.
Old Aug 14, 2008 | 06:35 AM
TKEVO's Avatar
Veteran: Air Force
Coo Coo. I don't usually hit that high just driving around. Does it still use a little Alky even if you don't hit 8lbs or more?
Old Aug 14, 2008 | 09:59 AM
bhood1's Avatar
I don't think so.....the activation light doesn't come on untill i reach 8 psi
Old Aug 14, 2008 | 10:08 AM
TKEVO's Avatar
Veteran: Air Force
Ok that's coo. I've heard some people have theirs cut on about 12-13psi. I guess it's just a preferance
Old Aug 20, 2008 | 10:31 PM
1QikEVO2NV's Avatar
I know this is slightly off-topic but has anyone used the snow kit with aquamist failsafe and the gauge? I have my snow kit coming on at 8psi -100% injection at 25psi but I was thinking about lowering that to 22psi. Any help you guys can give would be great.
