I need help with my HFS-5
Old Jul 22, 2008 | 12:40 PM
Import Junky's Avatar
I checked the mac valve setup a few times so I know it works. I just had Dudical pm me back stating that he heard of the V8 DDS3 having some bugs. What should pin #6 read when the gauge is on and vice versa?
Old Jul 22, 2008 | 12:57 PM
Okay so I'm reading 5 volts (pin6)on my meter regardless of condition. With the gauge on or off I still read 5 volts. I measured across pin 2 and pin 6 to get this reading. Is there something I'm missing?
Old Jul 22, 2008 | 02:38 PM
Boricua_Evo's Avatar
Did you "Ground" pin# 24 to ECU pin 58? Just curious...
Old Jul 22, 2008 | 03:22 PM
I'm almost positive I did this but I'll double check that too. Any and all help is appreciated. So which problem do you think this will resolve? The mac valve?
Old Jul 22, 2008 | 04:46 PM
Richard L's Avatar
The problem is in the gauge. Pin#6 should read 0.6V at the "off" position. This problem can only be caused by a broken component inside the gauge. We have never has this component failed once.
Solution: put a short between the two pins (with copper track) until I send you a replacement BAS16 diode.
You can also send the gauge back to me to repair, no charge.
Old Jul 22, 2008 | 07:44 PM
I'll have to get the gauge back out of the car. Hopefully I can do this. I'm pretty good at soldering wires, just never soldered components onto a board. I'll give it my best shot and if I fail I'll just send it to you. Thanks again Richard.
