Whats a low priced kit thats actually good
Im looking for a low priced kit preferable under 400 with all the failsafes. Anybody kno of any that are actually good
If you are willing to do some parts sourcing yourself, you can have a good and reliable system for under $400. With failsafe and dash gauge.
Link below:
https://www.evolutionm.net/forums/sh...d.php?t=239216
Link below:
The above diagram shows a more complete setup. All shurflo pump has more or less the same internals, the demand switch on the front of the pump determine the operating pressure.
The spring inside the demand switch is changeable, from 30psi-150psi. If you are running methamnol, ensure you purchase a pump with EPDM seals. (quite common).
This $400 system can be triggered by IDC, Mass airflow sensor (0-5v), MAP sensor, throttle angle sensor etc. ASnything that has 0-5V output.
yeap^ i was reading another thread where some guy got a HIGH quote to get this installed... ...but it wasnt as complicated as i thought, all the wires are colored to their matching station on the DDS box, and with the diagrams posted it makes it even easier...
can sombody give me good places to buy the extra parts...also which sizes and stuff do i look for...thanks
My post wasn't meant to say failsafes are junk but rather to say many kits have had problems with the failsafe failing making the kit dysfunctional.
You don't really need a ton of mechanical failsafes if you have gauges and auto map switching.
I have two partially completed alcohol/methanol kits (Engine Runup and Devil's Own) that I can sell you at a really cheap price. I've decided to go a different route. If you're interested, just let me know.
