Direct Port 100% H20, Proof of being the ultimate Injection!
Old Feb 24, 2009 | 09:36 PM
esevo's Avatar
Im still seeing threads and questions regaurding which mixture is the "best" even after the sticky up top was written lol. So I will just have to prove how water can really work. With the help of Richard L at Aquamist and the new HFS-6 kit being released soon, I will be doing a full test of this new system, and with that going for the ultimate power on 100% water.
I have upgraded Okada Coil packs so spark wont be an issue.
Jets x's 4 are special order 0.3MM delivering 98cc per min.
Water will be 100% distilled. Tests will be on a Mustang Dyno, Before and after.
Here is a sneak peak:
I have more pics to post but going to wait for the results, Just know its on a 2.3L with Gt35R twinscroll.
Thanks
Evan Smith
Old Feb 24, 2009 | 09:45 PM
nikkadanny's Avatar
whoa, crazy looking setup! my friend has been telling me to run water than meth
Old Feb 24, 2009 | 10:00 PM
fromWRXtoEVO's Avatar
Evan,
I swear I mentioned this at least 2 years ago when I first saw it on a Dodge SRT-4 at SIR from Justin. He use to have a Blue SRT-4 then he purchased a blue Evo 9 (he was from Tucson). It is a great idea to actually do it (you) and not just say it(me). I think it is an excellent idea and it is the typical project for someone like you with a lot of ambition that don't just settle for a standard set up. By the way,PM me your e-mail, I got to send you a couple of pictures on my Vette license plate..
Carlos
Old Feb 24, 2009 | 10:08 PM
esevo's Avatar
Carlos! Hi buddy! PM'd
Yes SRT4's are doing it as its very easy to remove there intake mani, however without a EMS its worthless.
You have to fully tune, and I think most srt guys use some meth (literally lol hahaha).
Once my car is done I wanna run that Z06! I think a 2.3L 35R should be a worthwhile race eh? lol
Evan Smith
Old Feb 24, 2009 | 10:10 PM
D420mac's Avatar
this is interesting. I'm running alcohol now and I recently went through rings, with alcohol being the possible culprit.
Old Feb 24, 2009 | 10:11 PM
D420mac's Avatar
I've got a 2.3L with a 35R it's a nice setup!
Old Feb 24, 2009 | 10:13 PM
esevo's Avatar
^^^ sad to hear about the motor, glad to hear about a similar set up.
Evan Smith
Old Feb 24, 2009 | 10:26 PM
Yeah, the idea of putting the nozzles individuallly is great because of the equal distribution of the mixture. Yeah, your 2.3l+gt35 against my Z06 sounds like fun, we just need a lot of road because I don't think neither me or you will pull easily on each other...
Take care and check your private e-mail. I sent you some pics.
Carlos
Old Feb 24, 2009 | 10:31 PM
D420mac's Avatar
but if one of the nozzles, clog and fail it can cause a big problem!! You could put all 4, or one large one on manifold.
Old Feb 24, 2009 | 10:33 PM
scheides's Avatar
EvoM Moderator
Sweet! Good thing you live in an area that never gets cold enough to freeze your injection fluid of choice
Old Feb 24, 2009 | 10:35 PM
D420mac's Avatar
True!!! I forgot to mention that. you could always add a bit of alcohol or meth to keep the water from freezing!
Old Feb 24, 2009 | 11:08 PM
esevo's Avatar
Yes I dont have to worry about freezing, and I have a lot of dry heat! East costers need and should add methonal during the winter months, but I hope your really not driving the Evos when its that cold lol.
I will be running 2 filters, not to mention only distilled water, clogging will not be an issue. Plus I will be running a Aquamist HFS-6 kit so no worries! One big jet in the IM will not distribute the water evenly it has to be direct port. The jets almost have a direct shot at the valves so I will be getting full water droplets into the engine. This is when a good ignition system comes in handy.
Carlos, Gearing will be my doom in a roll race you will clearly pull better. However it should be intresting up until that point lol.
Evan Smith
Old Feb 24, 2009 | 11:15 PM
Did you get the pics Evan?
Carlos
Old Feb 24, 2009 | 11:19 PM
esevo's Avatar
Yes I did.
Old Feb 24, 2009 | 11:23 PM
D420mac's Avatar
The water should vaporize there shouldn't be any dropplets? I love taking the EVO's out in cold weather snow is a blast, it's like a high speed snowplow LOL.
I want to see your results I have an SMC Alcky/water kit and I use it all the time due to running 30 lbs of boost. I upgraded my little tank to a 5gal fuel cell. It lasts for a few fillups. I use alot of alcohol and I am a bit concerned about the adverse effects of alcohol. Wouldn't the water cause some corrosion aswell?
