Smc/ Snow performance??
I purchased an smc meth kit with a snow performance fail safe from a good guy on these forums. He never used the kit he got it from someone else off the forum. Now i was wondering because the guy who had it hooked up had cut the wires and everthing is in a box and i have no clue what wires/ lines go where dose anyone have the wiring for this set-up im sure theres more of u guys running this set-up I need help hooking this up. Thanks guys. If you need pics of what i have put your e-mail up and ill e-mail what i have to you.
Thanks again.
SMC kit, hook up the colored wire to each other, all the wires should match. Then you will have a Red (power) and Black (ground). Just hook those up one to ground, other to an ignition hot (only hot when key is on, radio fuse works well). If you have an AEM, hook a T into the green wire on the set of 4 and it will hook into the nitrous port on the AEM, call Dan Buschur and he can tell you which one that is. As for the snowmeth failsafe, I cant help you there. If you have anymore questions, feel free to PM me as I dont check these parts.
05blue8
Feb 23, 2009 08:28 PM
StevenStarke
Jan 27, 2008 06:40 PM
EvoTech
10
Feb 16, 2007 03:30 AM
EvoTech
Jan 3, 2007 06:21 PM
