show me your meth kit setup!!
Old Apr 8, 2009 | 04:43 PM
Wickedwhite8's Avatar
I did mine from DG motors post looks great works great and you cant see it. Awesome post by the way DG Motors.
Old Apr 13, 2009 | 09:57 PM
pcamara17's Avatar
I got my tank and pump in the trunk but leaning against the back side I made brakets for it... it looks clean... when I get my car back from the dealership I'll post pics but it will not be for at least a week because they need to replace my whole transmission..
Old Apr 19, 2009 | 04:49 PM
wizzo 8's Avatar
DG Motors I thought you had to get power from a switched source and not directly from battery
Old Apr 19, 2009 | 05:02 PM
smokedmustang's Avatar
I'll show you my Meth-kit set up.................your not a cop are you????
Old Apr 21, 2009 | 06:08 PM
Cali2MDevo8's Avatar
Registered User
LOL
Can I buy a few gallons of that metH??
Old Apr 21, 2009 | 06:29 PM
Evoryder's Avatar
The cleanest way is to put it in the trunk opposite where the stock washerfluid goes. But if you're going to go big reservoirs here's what i did(see pic below).
Took out rear seats(easy), 3 strips of aluminum 1-1/4 wide 3' long per strip(home depot) Bolts used were 1.25x8mm ...length I believe 2"'s long. Measure drill holes, dremel. Took me about 4hrs to do including soldering and running lines. I used to have my setup in the front but decided to acquire a bigger set of tanks for less refilling.
I also have the upgrade 250psi Labonte pump running 2 nozzles.
NEW SETUP:
OLD SETUP:
Old Apr 21, 2009 | 06:34 PM
ExViTermini's Avatar
how well did that work out with the nozzle being in that location as opposed to up at the TB?
Old Apr 21, 2009 | 07:12 PM
Evoryder's Avatar
Didn't really have it connected at that position, only used one nozzle up until changing pumps. I have 2 nozzles now about 12"'s from the TB.
Old Apr 21, 2009 | 07:48 PM
SICK9's Avatar
my setup for the stealth look.
final look:
Old Apr 22, 2009 | 07:13 PM
wizzo 8's Avatar
Is it necessary to weld a bung to upper I/C pipe for nozzle or can you just drill and tap a hole in the pipe? Yes I know a welded in bung is the best bet but I was wondering if the easy method would be ok
Old Apr 22, 2009 | 07:19 PM
Evoryder's Avatar
You can tap it, however, the welding is the best option(less chance of a leak)
Old Apr 23, 2009 | 09:13 AM
DG Motors's Avatar
Thank You, I am glad it worked out good for you!
Depends on the kit, however most kits just need a direct tap off the +terminal.
NEW SETUP:
OLD SETUP:
Very creative and simple. Very nice.
final look:
Looks great man!!!
Old Apr 23, 2009 | 04:26 PM
Evoryder's Avatar
Thanks DG
Old Apr 24, 2009 | 07:34 AM
DG Motors's Avatar
Thanks DG
Anytime.
Old May 16, 2009 | 11:17 PM
Evoluvin's Avatar
nice!
