show me your meth kit setup!!
I guess Ill put mine out there. Cant really see that much but you'll get the idea.
Here's my relocated battery along with the 3qt tank against the back of the trunk and the pump is underneath the spare tire well.
Heres under the hood. You can see the jet on the 45 about 4" from the TB and the bracket is behind that holding the solenoid. Also on the right were the battery was is where the ifs is located.
This is the screen that comes with ISG-S3. The touch screen looks great and works good too.
Im going to be running my meth kit tommorow. how many feet of line did you guys use mine came with 15ft and it looks like im going to need more. can i use just a connector and add on?
any one use devilsown yet?
Mine came with 15ft also. I'd say the best way to do it is get your nozzle placement and solenoid placement set up because that is the least tubing used.
My jet is only about 3 in from my solenoid so the least amount of meth can sit in the line and get sucked out.
Then run your line on the under side of the car where the fuel lines are there is a extra space that 4mm tubing fits in perfectly.
Then run it to your pump and tank set up in the back.
Of course this is if your running a tank and pump in the back.
Did you search? Nope... https://www.evolutionm.net/forums/ev...-kit-evo8.html
