What EXACTLY is water/meth injection
why in the world with E85 being available would you want to run meth or even water?
Its been proven to be the cause of most engine failures out there from the major tuners.
Spend the money on injectors, pumps and whatever else you need and start running E85. You will gain more power and its safer.
The biggest problem is that typically one cylinder will mostly get more or less than the others and eventually pop goes the weasel.
I think most on here would HIGHLY recommend E85 or other modifications.
I have to think you can gain the same power safely as you can by installing meth. Its just not a smart move.
Trust me, this is coming from someone who ran 100% pure meth. Depending how much and how long you are in boost will determine how long the tank will last.
If your going on a longer drive, you constanly have to make sure you have a container of meth in your backseat to make sure that you dont run out. Its a pain in the butt to be honest with you.
If you must run it, run washer solvent, its the easiest to get, you never have to worry about running out, its all over the place.
TO AGMIST:
Dude, if you talk to the most highly rated tuners across the country, there is not one that recommends installing meth.
TO AGMIST:
let me rephrase the first line
IF E85 is available to you, why in the world would you want to run meth.
You really trying to tell me that running meth is safe for your motor?
why don't you research how many blown motors on this site because of meth...
do you think its because the nozzle location?
The tune?
No fail safes.....
you or no one else will be able to convince me that its safe on a motor. if it was, companies like, AMS, BUSCHUR, AWD would be pushing and recommending it to their customers.
I ran it for 2 years, luckily with no major problems however on the 3rd year it went boom!
I will never ever run it again..... nor do I think anyone who has blown a motor because of it will either.
I would rather make less power safely than run meth on my car ever again.
The tune?
No fail safes.....
The tune?
No fail safes.....
The tune?
No fail safes.....
I believe Buschur and AMS has supplied WI kits in the past. Buschur installs and recommends the SMC (now moved on), At one time some suggested aquamist to them but they delined due to complexity and cost.
ASM has tinkered on their own kit, again no failsafe. They have used and installed aquamist before but against due to complexity and cost, they prefered other kit with less features and failsafe.
I can see the problem with this industry, cost is the bottom line, quality and functionity is way down the list of preferences. I believe this is one of the main cause of people's view on a wmi system.
Slogen such as "Same power" at lesser cost. Most user has no idea what they are buying into until the engine goes bang. This is what makes the bad press. The cost of a true failsafe (direct flow read) is in the region between $100-200. The cost of a rebuild is several fold higher.
I am sorry that you are one amongst many that has turned your back on WMI due to bad experience. Unfortunately, we are in amongst that category despite the time and effort we spent on our own over the years. What can we do to address this?
TO AGMIST:
TO AGMIST:
The tune?
No fail safes.....
The tune?
No fail safes.....
I do not fill up my tank now but every 2wks, it that. I put a few hundred miles on my car every week and always get on it. I also have a map switch so I can run either my pump gas map or my meth map at any time. I do not have to drain my tank or hope that there is a station close.
Again, What failsafe/kit did you have. When did your motor blow?
Most people on here talking bad about meth can not seem to give any data. They just spit back out what they have heard online....
Ok so from looking around a little on this forum I can find...
7 motors blown on meth + pump
27 motors blown on pump only
1 motor blown nos
3 motors blown E85
8 motors blown while saying look at mod list. They do not currently run meth and make no mention of it or any other fuel.
I found it by searching threads under the title "blown motor" and looking through the thread "Various data on my blown engines". I will continue searching, but from this patern someone should warn the community.. "Dont run pump gas it will blow you motor!"...
The large majority of motors blown on pump only blew cyl #1 and cyl #4.
1 motor blown nos
3 motors blown E85
ignorance is bliss....
The tune?
No fail safes.....
The tune?
No fail safes.....
I'm probably buying an '05 MR this coming weekend that already has meth injection. It was installed by the PREVIOUS owner and tuned by AMS. That's all I know right now. Don't know concentration. Frankly I like the benefits but I DON'T know how it was set up and if properly. What I've been told is that the meth kicks in at 20psi (20g) up to about 24psi. I'm told I can turn boost down to 19 and never worry about the meth running out or screwing with motor. I might do this until I figure out how it was setup and what my options are. The things I've read here are making me nervous.
Motor internals are all stock. Standard bolt ons (Perrin fuel rail, Wahbro pump, 650cc injectors, Injen FMIC, 20g, HKS racing intake, Perrin/High Flow/RR stealth back exhaust, DC Sports turbo manifold, Invidia 02 housing), with 280 intake and exhaust cams.
Gah the injection kit is SMC trunk system. Installed at least two years ago. Don't know what percentage it is set at.
Edit: it's a 50/50 setup. That said, given that it's been used for at least 10k miles, am I safe?
Nice! Just found Devil's Own 50/50 mix. 4gal for $20.
You are safe. I would get a retune and turn up the boost. Also check to see if the system has any failsafes integrated. They make it much "safer" to run. If no failsafe make sure you check the fluid level before you go driving everytime. I would invest in a failsafe asap if none are present. I would also have a wideband and use the tephra options to monitor for knock. The last two recommendations would be good if you run meth or not.
27 motors blown on pump only1 motor blown nos
3 motors blown E85
I found it by searching threads under the title "blown motor" and looking through the thread "Various data on my blown engines". I will continue searching, but from this patern someone should warn the community.. "Dont run pump gas it will blow you motor!"...The large majority of motors blown on pump only blew cyl #1 and cyl #4.
3 motors blown E85
There is a nice video explaining the basics of WMI.
https://www.evolutionm.net/forums/wa...ml#post9197389
