Aquamist HFS6 Must Read
Old May 16, 2009 | 07:45 PM
K Scorcz's Avatar
Greetings everyone,
I was just finishing up the install on my new Aquamist HFS6 kit when I ran into a snag. A leak formed at one of the push fittings that could not be stopped. I chalked it off to being a defective fitting as the other one did not leak.
I e-mailed Richard from Aquamist who stated that I had installed the fittings wrong. I assured him I followed the directions and the diagram exactly and was certain it was a defective fitting.
After speaking to Richard over the phone he investigated the incident and discovered that the diagram that comes with the HFS6 kit is wrong. The old diagram shows the push fitting installed below the accumulator on the 5 way brass fitting. This is incorrect as it is the high pressure side of the pump. Richard further related that the metal screw type fittings should be installed below the accumulator as they are much more secure and made to withstand the high pressure .
A note to everyone who has or will install this kit. The plastic elbow fittings do not go on the pressurized side of the pump as they are not meant for high pressure and will leak.
A big thanks to Richard for taking the time and getting to the bottom of this problem. A+ customer service.
Below is the updated diagram.
Old May 16, 2009 | 08:49 PM
burnzy's Avatar
lucky me I was too dumb to follow the manual correctly and actually have it right
Old May 17, 2009 | 02:26 AM
Richard L's Avatar
Thanks for posting this, we apologised for not making it clear. I would also like to add another oversight of the RJ plugs. Not all harnesses have this defect. Please clear the overhang with a small knife or return the harness to us.
Old May 17, 2009 | 08:04 AM
Richard L's Avatar
This recommendation would not apply if the water filter is installed in the horizontal orientation.
If the inline disc is installed in a vertical position, it would be advatagous for inlet to be located at the bottom and water exit at the top. This will avoid debris from settling on the filter mesh and cause premature clogging.
Old May 17, 2009 | 08:05 AM
Richard L's Avatar
If wire leading the the FCM (flow control module) is at a higher level then the module, it would be advisable to create a small downward loop to allow any water trickling along the line working its way into the FCM.
blacktab420
Feb 2, 2016 09:51 AM
megavar
Sep 23, 2008 10:58 PM
fred 62
15
Nov 15, 2007 04:56 AM
Richard L
22
Apr 24, 2007 01:53 PM
Richard L
11
Mar 29, 2007 01:30 AM
