Two HSV's with one Aquamist controller
Hello,
I am wondering if Richard (Aquamist) or someone else, can tell me whether the aquamist system in it's standard form (eg HFS 5) is capable of controlling two high speed valves in parallel?
If not, is there an efficient way of doing this?
cheers
Matt
cheers
Matt
They will run the same duty cycle though, how could you have them perform different jobs?
Please explain what you plan to do.
Unless you want to run different liquids through each, then I understand.
Dudical,
I have a spare ERL pump, injectors and HSV, so I was going to "upgrade" the intercooler sprays to run at a higher pressure using aquamist bits. I was hoping to get better atomisation than the standard unit.
I was thinking to activate it from the aquamist system, so it fires whenever the meth injection is running.
I will use the standard tank with a diluted meth/water mixture.
fred 62
15
Nov 15, 2007 04:56 AM
binh
40
Sep 10, 2007 12:32 AM
Richard L
11
Mar 29, 2007 01:30 AM
