A new generation of water/methanol tank design ... by Howerton Engineering
Wow, that looks awesome.. Im thinking of getting into water/meth injection and something like that tank would be sweet.. not only that, Id love to try and run pre-turbo injection as well..
My Howerton Install Location
Since I haven't seen anyone post pics of their actual install, I thought I'd share mine. The box is located on the driver side of the trunk. It fits nicely there. If you look close in the pics, you can see two sguiggly magic marker lines on the floor of the trunk. Those two lines follow two rows of spot welds on the trunk floor. There is plenty of metal there to use self tapping screws and have it hold nice and tight. I used 6 screws, but I'm sure 4 would work. Although the screws aren't in the corners of the box, I'm not concerned at all about the sturdiness of the mounting. You can also use nuts/bolts, as the bottom is easily accessed from under the bumper without having to remove anything.
I tell you, the craftsmanship of this box/setup is top notch! I opted for the baffled tanks and the ventilation fan, as I plan on using this setup for hot laps on a road course. Can't wait to take it to the track.
blacktab420
Feb 2, 2016 09:51 AM
Mellon Racing
Feb 22, 2011 01:56 PM
Richard L
252
Dec 14, 2010 05:03 PM
Richard L
146
Aug 31, 2010 03:25 PM
Richard L
791
Jul 17, 2010 09:24 AM
