which water/meth kit should i go for?
I have an HFS-1 kit for sale, if you're interested. Make an offer:
https://www.evolutionm.net/forums/sa...-hardware.html
The Post
My car made 80whp on a 50/50 mix on a conservitive tune. The coolingmist kit was a flop, never worked right so I ripped it out. I am going to buy a Auqamist HFS-3. You really don't need the 6, some of the features on the 6 you would never use anyway. IMO.
I will post dyno results in a month or so when all is installed and dialed in.
Jeff
Jeff
Also, real quick. MAKE SURE your tuner does dyno pulls In the Lower gears BEFORE he/she takes your car off the dyno. Especially on a stock Trubo. Seems there are knock issues from the turbo boosting quicker than the meth can get there. If you run an Aquamist with the FAV you should be ok, or a bigger turbo like a Red or A Black etc, but do yourself a favor and have the tuner do a pull in 1-3 on the 5spd and 1-4 on the 6spd. Just to check for knock. Meth is a great choice, but is very very deliquate. A great choice if E85 is no where near. IMO
Note though, most tuners do not like tuning cars on meth. At least here in So Cal.
LancerCALI88
11
Apr 3, 2004 01:36 AM
