Tune on 50/50 Water Meth
Subscribe
Jun 21, 2010 | 10:47 AM
I have a AEM one generation older meth kit which doesnt come with check valve
I bought a mechanical check valve n fitted it
i run it in a Evo III , 2.0, FP Green , aiming for 30-35psi of boost
it did hit 420 on a dynojet with 30psi of boost on 93 octane fuel
i fitted the medium nozzle size by AEM rated for 300-450hp engine
the car is currently misfiring and jerking when the injection starts
i have set the AEM to start at 10psi (backdraw of the AEM minimum 10psi set)
how should i go up with the tune , should i tune it to be leaner a lil bit first or should i go for higher timing first ?
thank you
Reply 0
Nov 16, 2010 | 11:14 PM
You might be injecting too much for the airflow you are currently running. Also, the water/meth can cause a misfire if you are running too wide of plug gaps or have a weak ignition.
What AFR are you logging when it comes on?
Reply 0
Subscribe
