HELP: AEM failsafe
Old Apr 30, 2010 | 06:21 PM
jdmevo123's Avatar
HELP: AEM failsafe
Hi Guys,
I am from australia and tried to order the jack of the trades harnes, I then found out shipping was $95 bucks so I was not impressed.
I then went to Wiki and found the wirin diagram for the alt map harness, I made this and it works perfectley in theory, I am currently trying to find a wiring diagram showing How I integrate the AEM failsafe wire into the harness to swap back to safe maps if it detects a problem.
If anyone knows how to wire it in it would be much appreciated.
Thanks
Dale
Old Apr 30, 2010 | 07:58 PM
jdmevo123's Avatar
come on guys, someone has to know.
Old May 2, 2010 | 07:38 PM
tephra's Avatar
does the AEM have a failsafe output?
what sort of voltage does it output when its good/bad?
Old May 3, 2010 | 12:13 AM
jdmevo123's Avatar
Hi tephra it has a green wire that grounds when failsafe is active.
I was thinking of using a car relay and if grounded it would stop all power to the harness. What do you think?
Old May 3, 2010 | 12:15 AM
tephra's Avatar
so does it supply a + voltage when the failsafe isn't active (ie system ok)?
Old May 3, 2010 | 12:24 AM
jdmevo123's Avatar
Um no I think it just grounds itself. It's actually a boost control release valve line that you can use to vent all boost if system has failure.
I read a forum that used the at relay to switch on or off. But I thought I would ask here as jot ha created a harness for this injection kit and I already have the harness I just need to know how to wire the aem to the harness and if it uses a relay ect.
Old May 3, 2010 | 12:34 AM
tephra's Avatar
hrmm thats a bit of a pain... an idea on how much current it can carry?
you would need get a relay between battery positive and the AEM failsafe line
the relay contacts would then need to connect the JoT harness (5v output) to the ECU...
Old May 3, 2010 | 09:41 AM
NS@AEM's Avatar
Error driver is rated to 1.7 amps.
Old May 11, 2010 | 09:18 PM
jdmevo123's Avatar
Thanks NS,
So if I use the harness with 12+ power routed through a standard relay and when the aem failsafe kicks in it will cut out the 12v power therfore switching the maps?
Is there a way I can implement the relay to also toggle a failsafe switch that will not let power run back through the harness until I let it?
Old May 17, 2010 | 03:43 AM
John F's Avatar
This is the diagram you need.
Attached Thumbnails HELP: AEM failsafe-aem_setup.png
Old Mar 30, 2016 | 03:12 PM
alexis21's Avatar
Do you check it? Is this diagram working?
Old Apr 20, 2016 | 03:00 PM
okevolutionVIII's Avatar
^^that post was made in 2010. I've been looking for this info for about 16 months now for using the stock ECU, DevilsOwn stage 2 methanol kit, and the AEM failsafe gauge. and looking at the diagram, it makes sense and I will be testing it soon to see if it works for my needs.
05EV08
Aug 30, 2025 02:29 AM
rado
AEM EMS
Oct 17, 2016 08:29 PM
picco97
May 3, 2016 09:54 PM
alexis21
Feb 22, 2016 05:20 PM
