How do u choose the right nozzle size?
Old Dec 9, 2010 | 05:24 AM
  #46
03evilution's Avatar
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
here is an email i got from Jeff Howerton about IDC i found interesting and pertains to the thread
" unless your IDC is very low, 50-60% range, since the Aqumaist tracks your IDC it's all relative. So if you are at 70% or 90%, the system matches your IDC so it will be fine"
Originally Posted by mt057
Are you going to use the multiport bar for spliting off for the three jets?
Jeff said i would be using the 4 port bar for splitting off for the three nozzles since its a compression fitting and better suited for the 100% denatured alcohol
Old Dec 9, 2010 | 09:02 AM
  #47
mt057's Avatar
I found that since I was at 70% IDC at peak that I had to add some gain back in to help compensate. I said screw it and put in the two 1mm jets. Now its back to tunning and having enough is not a problem.
I was going to purchase a 4 port bar but they were not ready, when I put my kit together.
Why denatured alcohol over methanol?
Old Dec 9, 2010 | 09:23 AM
  #48
mt057's Avatar
Originally Posted by 03evilution
1450x4=5800
5800x25%=1450
1450x1.1=1595
1595/3=532
532 in the 130-140psi pump range is 1.0mm at least from what i got and the reason for the bigger injectors is because of what i have now and the block that im having built. having a 2.4 longrod built and a huge turbo going on my build that should put me over 600whp so thats why the big injectors. what i have now on high boost with the meth should put me over 500whp..... lmk
OK jeff explained it to me I was making it too complicated. I was trying to add the IDC comp back in and you don't need to unless its really low like you said. Also the step in bold was to add a little back in due to mechanical losses due to setup...
Old Dec 9, 2010 | 09:27 AM
  #49
mt057's Avatar
Originally Posted by wizzo 8
625 snow performance nozzle with controller. I have the Aquamist failsafe with flow gauge
I will have to look into the snow performance to give you a good answer. I would see if you could run two nozzles that would equal up to about the same spray as the individua nozzle. This would definetly give you better and faster atomization. I am assumeing that the kit is progressive. Some of those can take time to build up pump speed and it may not have time to build up flow as you stated.
Old Dec 9, 2010 | 09:46 AM
  #50
yea i just followed all the steps on the site
easier for me to get my hands on since any home depot or lowes carries it and just as effective
Old Dec 9, 2010 | 05:41 PM
  #51
wizzo 8's Avatar
Yes it is progressive. For next summer if I dont go E85 I will go to 2 nozzles. I also want to get away from the progressive crap.
Old Dec 9, 2010 | 11:51 PM
  #52
Richard L's Avatar
wizzo 8
I may be wring, didn't you have an aquamist HFS-1 before?
Old Dec 10, 2010 | 04:41 AM
  #53
wizzo 8's Avatar
Originally Posted by Richard L
wizzo 8
I have that as my failsafe only. You helped me in the past with it
Old Dec 10, 2010 | 11:26 AM
  #54
Richard L's Avatar
Which version # of DDS3 do you have?
All DDSv8 on has an output for powering up an inline valve. Putting an online valve to your existing system might help retaining some line pressure. All PPS systems run on a bit. Why not use it to your advantage. Allow the "run-on" to pressurise your system rather dribble fluid into your intake.
Old Dec 10, 2010 | 11:40 AM
  #55
wizzo 8's Avatar
Not sure what version. I think V10 if that makes sense.
I have a check valve to help dribble. I think ill just have to have this control everything and get rid of the snow performance controller.
Old Dec 10, 2010 | 01:05 PM
  #56
Richard L's Avatar
If you have a v10, you can turn your current system into a fully progressive IDC system by adding a fast acting valve, the v10 has an internal IDC to FAV converter.
Preferably, your pump is a constant pressure, bypass type set to 125-160psi.
Old Dec 10, 2010 | 04:19 PM
  #57
wizzo 8's Avatar
I might have to do that for next summer. I have the new style 250psi pump but it has the push in style hose fittings. I would also need the adaptor to hook up that FAV. Does it open the inline valve based on IDC then?
Old Dec 11, 2010 | 12:40 AM
  #58
Richard L's Avatar
First of all, I need to know the exact version of the DDS before advising turn your system into a progressive IDC system.
The 250psi pump will not work well with our system because:
- Rate of tempearture rise on the pump is too severe for a constant pressure system
- The line pressure is too high for our valve to work effectively, dynamic range will suffer.
- You need to change the by-pass spring to reduce pressure
- At 160psi, our valve can deliver in excess of 1500cc/min. More than enough for two jets.
May be we just leave things as it is.
QwikEVO
Aug 16, 2015 11:25 AM
TIGERJC
Jul 13, 2015 05:35 PM
STi_kill3r
Apr 6, 2012 12:13 AM
Biggy VIII
10
Nov 19, 2010 12:56 PM
dubbleugly01
57
Mar 3, 2010 08:58 PM
