water/meth on DD
Old Dec 13, 2011 | 03:11 AM
evoxsi's Avatar
im at 20k on my aem kit. if ur not boostin ur not usin meth.
Old Dec 17, 2011 | 03:36 PM
Schmidty7's Avatar
thanks guys for all the feed back im just up in the air about upgrading from stock turbo or running meth. decisions decisions
Old Dec 18, 2011 | 05:48 AM
sparky's Avatar
Originally Posted by S13 Curtis
.... my Aquamist HFS1....took me over 600whp with the stock block with ease....No problems here.
.....and ONLY 600WHP WITH EASE on the stock bottom! Uh-Huh. I am sure there's still a lot left on the table.
Old Apr 22, 2012 | 05:31 PM
xtruemassacre's Avatar
you could set it up on two maps...
one for DD where you could have the WAI at much higher RPM and not as frequent or even not at all,
then have a map for track use where it's active through most gears,rpms etc.
Old Apr 22, 2012 | 06:19 PM
shaman's Avatar
Schmidty7, is your turbo going bad? Just to offer a point of view, water meth will benefit you at most any point in the modding scheme. It will be more beneficial if other things are lacking (i.e. smaller turbo, less IC, etc), but you can always benefit from water/meth. With tephra map switch, I would, and probably will with a DSM and ceddymods, or EVO/Tephra if I find a really good deal, have a stun, and kill map. Stun running pump fuel with the water/meth turned off. Turning on the water meth turns on the alt map set for kill. More boost/timing.
On the other hand, a bigger turbo will reduce the need for charge cooling if you are running it at a better efficiency point than the stocker. If not, then you have the same problem, only at a higher power. Properly setup failsafes work. Take a look at the aem saved my 400hp ____, can't remember right now, on youtube.
My thought, from a monetary and a tuning challenge standpoint, is to max out the setup you have, then when the turbo goes out, or you find yourself at the point of diminishing returns, or with an excess of money, upgrade the turbo.
Old Apr 23, 2012 | 10:51 AM
Schmidty7's Avatar
Thanks guys for all the info! I've decide to go a different route and my 3582 kit should be here today!! Can't wait!
Old May 24, 2012 | 01:37 PM
Schmidty7's Avatar
for those of you who run water meth on a daily basis how do you have it set up are you guys running just a single jet or do you have each runner taped?
Old Jun 5, 2012 | 07:42 PM
mario1o1's Avatar
most ive seen are post intercooler and pre throttle body. you want it to be before the IAT sensor so your EMS can calculate the proper fuel. Its not uncommon to see below ambient temps with Water/Meth injection.
Old Jul 12, 2012 | 11:41 AM
loyal0ne's Avatar
i drive on meth as a DD for about 20K miles - Labonte kit spraying at 5-22psi No issues. As others mentioned, if you arent boosting, you're not using the meth. i don't even go through that much meth. a 5 gallon pail lasts me almost a year or so.
Old Aug 9, 2012 | 10:17 PM
Julio@Bisimoto's Avatar
I have great luck with my AEM meth kit, with one gallon bottle it will last about a month if I'm driving aggressively and have not had an issue on my DD.
Old Feb 7, 2013 | 09:15 AM
st0mp860's Avatar
Is meth bad for your car? I hear E85 is because it dries out the O rings..? How about meth?
Old Feb 7, 2013 | 07:50 PM
turbojoe's Avatar
I think with ethanol fuel its just since it is more corrosive than regular 93 it is worse on components as far as longevity is concerned. Components being fuel lines, tank, pump, injectors ect. But you can buy ethanol specific components for a more bullet proof system. The methanol kit is its own system. It sits on its own tank, flows thru its own lines, pump and injectors (nozzles) so there's not alot of concern with it sitting up too long and breaking down components. Plus meth is only injected for seconds at a time compared to car running e85.
I personally have no e85 experience so someone else can probly hit this subject better. I do however use a aem meth kit in my Evo every single time I exceed 11psi....love it.
Old Feb 10, 2013 | 08:32 PM
gear head's Avatar
A properly tuned, installed, maintained & working system will have no ill effects on the engine. With a W/M50 mix it will actually be "softer" on the bottom end than e85 even when running it on the edge.
Old Feb 14, 2013 | 11:24 AM
Evo11V's Avatar
Veteran: Army
I've been running it for years, I want to say for about 6 years and drive it daily using 100% Meth mix.
Old Feb 14, 2013 | 11:26 AM
Evo11V's Avatar
Veteran: Army
I'm running about 35psi peak which creeps down to 29/30.
