-   Water / Methanol Injection / Nitrous Oxide (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide-173/)
-   -   Snow's Safe Injection Integrated into SMC Alky kit! (https://www.evolutionm.net/forums/water-methanol-injection-nitrous-oxide/247197-snows-safe-injection-integrated-into-smc-alky-kit.html)
EvoTech Jan 23, 2007 07:51 PM
Well, after weeks of trial and error I finally have it all figured out and I will pass it on to anyone else looking to build in a safety for their SMC kit. Full write up with pics tomorrow. For now I can say that the key ingerdiant to make this all work was a $23 hobbs (pressure) swith set at 15 PSI so it triggers the safe injection after the SMC kit is already spraying but before you reach dangerous bost levels. This makes the safe injection a stand alone and does not need to share wiring with the SMC kit which is I found out is impossible because the SMC kit uses a progressive ground to trigger the pump. More to come.
Turbo Kyle Jan 23, 2007 08:44 PM
Nice!
JMPZ Feb 3, 2007 12:03 AM
thats awesome dude thanks for the info
Evotech8 Feb 3, 2007 01:31 PM
Cool...i like the stand alone safe injection idea.
Wish SMC would finally get the hint :rolleyes:
xxtomxx Feb 4, 2007 09:31 PM
is this worst than nos and what the diffrent in performace
Ultimate CC Feb 4, 2007 09:52 PM
Do some reading and then pm me when you have some specific questions...
homemade wrx Feb 4, 2007 10:05 PM
funny, in your other thread on the pressure switch, this was the single reason I asked where you sourced it from...I look forward to seeing your write up and repeating it on my smc kit :D
cfdfireman1 Feb 5, 2007 07:53 AM
Where?
Never mind.
vmsturbo Feb 15, 2007 07:28 AM
Any updates? I'm curious to hear about this failsafe.
Ultimate CC Feb 15, 2007 07:49 AM
You need to buy a boost pressure switch, two fittings and then the safeinjection and wastegate upgrade from me...
EvoTech Feb 16, 2007 03:30 AM
Sorry. I moved it to another section. It is all right here.
https://www.evolutionm.net/forums/sh...d.php?t=247321
