Snow's Safe Injection Integrated into SMC Alky kit!
Old Jan 23, 2007 | 07:51 PM
EvoTech's Avatar
Well, after weeks of trial and error I finally have it all figured out and I will pass it on to anyone else looking to build in a safety for their SMC kit. Full write up with pics tomorrow. For now I can say that the key ingerdiant to make this all work was a $23 hobbs (pressure) swith set at 15 PSI so it triggers the safe injection after the SMC kit is already spraying but before you reach dangerous bost levels. This makes the safe injection a stand alone and does not need to share wiring with the SMC kit which is I found out is impossible because the SMC kit uses a progressive ground to trigger the pump. More to come.
Old Jan 23, 2007 | 08:44 PM
Turbo Kyle's Avatar
Nice!
Old Feb 3, 2007 | 12:03 AM
JMPZ's Avatar
thats awesome dude thanks for the info
Old Feb 3, 2007 | 01:31 PM
Evotech8's Avatar
Cool...i like the stand alone safe injection idea.
Wish SMC would finally get the hint
Old Feb 4, 2007 | 09:31 PM
xxtomxx's Avatar
is this worst than nos and what the diffrent in performace
Old Feb 4, 2007 | 09:52 PM
Ultimate CC's Avatar
Do some reading and then pm me when you have some specific questions...
Old Feb 4, 2007 | 10:05 PM
homemade wrx's Avatar
funny, in your other thread on the pressure switch, this was the single reason I asked where you sourced it from...I look forward to seeing your write up and repeating it on my smc kit
Old Feb 5, 2007 | 07:53 AM
cfdfireman1's Avatar
Where?
Never mind.
Old Feb 15, 2007 | 07:28 AM
vmsturbo's Avatar
Any updates? I'm curious to hear about this failsafe.
Old Feb 15, 2007 | 07:49 AM
You need to buy a boost pressure switch, two fittings and then the safeinjection and wastegate upgrade from me...
Old Feb 16, 2007 | 03:30 AM
EvoTech's Avatar
Sorry. I moved it to another section. It is all right here.
https://www.evolutionm.net/forums/sh...d.php?t=247321
DynoFlash
Feb 16, 2010 11:44 AM
702RSevo
35
Nov 14, 2006 02:49 PM
AF-Evo8
Jul 21, 2006 01:09 PM
gsujeff55
Mar 11, 2006 12:47 PM
