Stage 3 Installation Specials Announced Officially!!!
GRUPPE-S STAGE III POWER PACKAGE (425HP)
Our Stage 3 Power Package begins by swapping the stock 16GL turbo for the much larger Garrett GT3071. The Garrett GT3071 is a Garrett medium frame turbocharger featuring a T3 turbine wheel and a 71mm compressor wheel housed in a ball-bearing center cartridge. The ball-bearing center cartridge ensures optimal turbo response and spool up, while the much larger T3 turbine and 71mm compressor substantially increases the power potential of your Evolution.
The larger GT3071 turbocharger will increase pump-gas potential by over +30whp over our Stage 2 package, with a overall horsepower increase of 110 to 115 whp (~145HP) over stock. The GT3071 was selected as the optimum Stage 3 turbo because it provides a substantial power gain without sacrificing turbo response, spool-up, and everyday driveability. Furthermore, it does not require the upgrade of the stock intercooler, hardpipes, or any other components other than the existence of the Gruppe-S Stage 1 and Stage 2 power-packages.
In terms of additional components only the Helix 720cc injectors are required to supplement the additional fuel needed (assuming you have our Stage 1 / 2). The ATP GT3071 kit WILL replace your factory downpipe.
And of course substantial tuning is required for proper operation, therefore the use of the Gruppe-S Reflash is mandatory.
(Quoted output is for cali 91 pump gas. The package is worth about 500HP on race gas, properly tuned).
Included in the Package:
*ATP GT3071 Turbo
*ATP GT3071 Parts Kit w/ Tial 38mm Wastegate
*Helix 720cc Injectors
*Gruppe-S Reflash
*Professional Installation
*Professional Dyno-Tuning
$2999!!!!
(+ tax on parts)
(Parts Only = $2299 Shipped!!!)
GRUPPE-S STAGE IV POWER PACKAGE (2.3 Stroker Motor)
With our Stage 3 kit on race gas your stock motor is pretty much at its maximum >reliable< potential. Our Stage 4 Power Package transforms your Evolution VIII / IX to a street and track monster. Our Stage 4 Power Package takes the venerable 4G63 and transforms it to a 4 cylinder monster by increasing displacement from 2.0 -> 2.3 liters and swapping the stock internals with completely forged internals and race bearings. Eliminated are the frequent causes of 4G63 failure - spun bearings and cracked pistons. The stock bore is increased from 85mm to 85.5mm and the stroke is increased to 100mm. The result is an extra 0.3 liters of displacement, with compression remaining right around 8.8:1.
Included in the power package is the Gruppe-S 100mm forged crankshaft, Helix forged connecting rods with ARP L19 rod bolts, Wiseco custom spec pistons, and Gruppe-S coated race bearings. The end result is a big power monster that substantially increases power throughout the power band. The added displacement is perfect for big turbo cars as well as track and road-race applications.
If you choose to have us build your block for you, we ensure that your engine is specifically suited for your high-performance needs. The crankshaft is carefully balanced within +/- 1 gram, the cylinder walls bored and honed, and the entire rotating assembly balanced. Our Stage 4 built motors can reliably sustain upwards of 550whp, which is in excess of 700HP. Special crankshaft services such as nitriding and cross-drilling are available.
2.3 STROKER PARTS KIT
-Gruppe-S 2.3 Forged Crankshaft
-Helix L19 Forged Connecting Rods
-Wiseco 85.5mm Forged Race Pistons
-Gruppe-S Coated Race Bearings
-This is a Complete Parts Kit!!
$1399 Shipped!!!!
Complete 2.3 Stroker Short Block!!!!
-Professional Bored, Honed, Etched, etc.
-Professionally balanced assembly
-All tolerances checked, no excessive oil consumption, no wobbly pistons
-NO CORE CHARGE!!!
$3799 Shipped!!!!
Need installation?
We'll install and dyno tune the 2.3 Stroker short block for you - $4259 (you give us your working core). What does that include? Well you drive your 2.0 car in and you'll leave with a tuned 2.3 stroker. You will probably want to have a GT3071 or larger.
Please contact us for any additional questions or to make an appointment. To view our staged packages:
http://www.gruppe-s.com/Evo/EvoPwr.html
Thanks!!!
Gruppe-S
www.gruppe-s.com
510-783-5300
510-783-4300 fax
*ATP GT3071 Turbo
*Gruppe-S Reflash
$2999!!!!
$1399 Shipped!!!!
-NO CORE CHARGE!!!
$3799 Shipped!!!!
Need installation?
Thanks!!!
Gruppe-S
www.gruppe-s.com
510-783-5300
510-783-4300 fax
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
165
Dec 15, 2009 10:15 AM
Gruppe-S
Apr 13, 2007 06:48 PM
Gruppe-S
35
Apr 9, 2007 08:21 PM
Gruppe-S
29
Nov 30, 2006 12:18 PM
Gruppe-S
Jul 6, 2006 04:46 PM
