Looking for desert alky advice
Old Apr 4, 2007 | 09:24 PM
Jim in Tucson's Avatar
I'm looking for any/all specific advice concerning meth/alky use in the Tucson/Phoenix area (or any really hot low humidity climate for that matter).
What are you guys/gals using for actual injectable, where do you source, which alky kit, what size nozzle, what %, and any other info that might be useful in my battle with ACN91.
Thanks,
Jim in Tucson
Old Apr 11, 2007 | 06:06 PM
Wow, 15 people read my post, but not a one had an opinion on alky, meth, etc. in the desert. We have the worst possible gas in the country. I would presume there to be a wealth of alky injection advice in Arizona, CA, and Nevada.
Do you use alky or meth? Do most of you use it straight? Mixed with H2O? What precentage? Where is the best place to buy? Which size nozzle? Which injection system?
Thanks,
Jim
Old Apr 12, 2007 | 02:24 AM
homiusang's Avatar
I had Coolingmist kit on my STi. Forgot which size of nozzle it was, but it comes standard with the kit and is good for stock turbo. I mix it with distilled water 50/50. You can source pure methanol from your local race fuel distributor. I bought it from Western States Patroleum in central Phoenix. Cost is around $4/gal (don't remember exactly).
Hope this helps.
Old Apr 12, 2007 | 04:52 AM
Ultimate CC's Avatar
I have a couple customers out in Az, ill see if I can get one of them to chime in for you...if you have any questions let me know...before I could suggest a kit and nozzle size and the rest I would need to know your mods...
Old Apr 14, 2007 | 03:53 PM
Currently:
Stock turbo
Stock motor (w/cams)
K&N drop-in
Hallman MBC @ 21.5psi
Forge by pass valve
Helix down pipe
Helix test pipe
Greddy EVO2 cat-back (modified)
HKS 264/264 cams
Nisei LICP
Walbro 255Lph fuel pump
ACN91 fuel
303 HP & 308 ft lbs
AFRs 11.2:1 from 4,500rpm
In stock:
SS O2 housing
On order:
ported stock exhaust manifold
Will be on order soon:
EVO Green rebuild
Thanks for your advice CC.
Jim
Old Apr 14, 2007 | 05:21 PM
with the mods you have your are going to want something with a progressive controller for sure...then you have to decide if you want a failsafe, and etc etc etc...
Old Apr 14, 2007 | 05:27 PM
Rez90's Avatar
smc v 2.0 alchy kit running straight meth with AEM failsafe and boost control.
2+ years, 35 pounds of boost. No problems.
Old Apr 14, 2007 | 07:25 PM
Ralph's Avatar
35 lbs, on ...... 93-94 octane + meth?
Old Apr 14, 2007 | 09:09 PM
yea man, i ran over 35 on a stock turbo plus nitrous and meth
Old Apr 14, 2007 | 09:20 PM
evoteddy111's Avatar
ultimate CC how much power if it all goes swell???
Old Apr 14, 2007 | 09:37 PM
with meth injection on stock turbo you pick up 30whp and 40wtq typically...it varies from dyno to dyno and tuner to tuner...
Old Apr 14, 2007 | 09:57 PM
CC,
I'm sure you've seen some of the recent chatter concerning corrosive effects of meth. What is your take on the negatives of using meth?
What about alky? Is it safer? How much less in power than your "30whp and 40wtq" estimate? Is alky half as beneficial? 75%?
Thanks,
Jim
Old Apr 14, 2007 | 11:37 PM
evolancer04's Avatar
If your running a hydra standalone, they have a badazz water injection kit that works in conjunction with the standalone. It's called hydra mist. It has all the fail safe precautions that work off the standalone.
Old Apr 15, 2007 | 08:19 AM
Well 100% meth is pretty corrosive but you would really need to spray like a 100gallons I would think before you saw any negative effects...I did over 60 with 50% in a year and my motor was fine when I pulled it apart...I suggest running between 50 and 75% and calling it a day...you can run denatured as well but its also a lot more money per gallon...
Old Apr 15, 2007 | 08:25 AM
o u get meth at???
