Las Vegas Evo's
Old Sep 5, 2008 | 05:24 PM
  #46891
bchappy's Avatar
You are using actually a 1/3 more
typically you will see 15-17MPG if you dont drive like a jack ***.
however with the price of E-85 it is a 1/3 cheaper than 91.... so you will have to fill up more but your fuel costs are equal to 91.
105 octane at 91 fuel cost=bueno.
there are guys running E85 in sub zero climates and not having the problems that are being told.
but then again I have a ICS switch and i switch in between maps.
Old Sep 5, 2008 | 06:57 PM
  #46892
bzzbee2's Avatar
Yea that is good info... However, I would not say that you use 1/3 more... i was getting 17-19 before, now i get 16-17. You can also put a Ethanol content gauge on your car that will tell you your exact percentage of ethanol in the tank.
With our climate here you dont really have to worry about the cold thing. As far as oil... I have done quite a bit of research on this one.. i have been having mine analyzed every 1k miles since the switch just to see how much fuel ends up in the oil and if there is any excessive wear due to the fuel. All is good to go 4k miles and i should have the results back from 5k in a week.
I still only fill up once a week.. but now instead of spending 46 dollars i spend 34.
Old Sep 5, 2008 | 07:05 PM
  #46893
EvoFredo's Avatar
Brake rotors
does anyone know a local shop that will do a good job and priced well to resurface rotors. for how much and where have you guys had good luck at. thanks---
Old Sep 6, 2008 | 02:09 AM
  #46894
1freshKid's Avatar
I've been using the same map i was using for 100 and where before i had a little knock somewhere i now have none at all. I didn't upgrade a thing except i already had a walbro installed. The car runs fine except a CEL came on of P0134. Might be cause i'm not tuned.
Old Sep 6, 2008 | 10:27 AM
  #46895
Go_Lancer_Go's Avatar
Im looking for:
Defi BF Boost Gauge in Imperial(PSI)
and
Link Control Unit V2 (Main Unit)
Anyone selling any of these, lemme know please. I have money ready 2 go!
Old Sep 6, 2008 | 10:31 AM
  #46896
PWevo's Avatar
What's up everyone, I'm moving to vegas in the next couple weeks and need to get re-tuned for the wonderful 91 octane you guys got there. Previously tuned on 94 octane, any recommendations for tuners?
Old Sep 6, 2008 | 11:20 AM
  #46897
SinCityEvo9's Avatar
pm 20psiMR....he can street tune your car for you when you get in.....his name is chris
Old Sep 6, 2008 | 12:54 PM
  #46898
fimotorsports's Avatar
call Doug at Dougs Dyno 702-336-2275
Old Sep 6, 2008 | 07:30 PM
  #46899
RC2099's Avatar
Anybody need thier car detailed next weekend? I have Sunday open.
Scott
Old Sep 6, 2008 | 08:57 PM
  #46900
EvoFredo's Avatar
Brake rotors
Got my rotors done today, they came out great. Big thanks goes to DJ.B rian for all the help
Old Sep 6, 2008 | 09:18 PM
  #46901
dj b_rian's Avatar
no problem man, i'm glad to hear that the rotors stop smooth. let me know if you need any other work done to your evo.
Old Sep 6, 2008 | 11:11 PM
  #46902
bzzbee2's Avatar
your using e85 on a 100 tune... thats not the smartest thing to do. Your gonna be running pretty lean. The reason you need to retune is to get the injector scaling correct.
Old Sep 7, 2008 | 03:40 PM
  #46903
BoostN's Avatar
Concure.
Old Sep 7, 2008 | 04:07 PM
  #46904
1freshKid's Avatar
Thanks your advice is mucho appreciated!!! So looks like i'll be taking a trip to cali for a e85 tune and buying new injectors.
Old Sep 7, 2008 | 04:34 PM
  #46905
bchappy's Avatar
^holy ****.
