Las Vegas Evo's
Originally Posted by joEvo8
Here are the mods I have: INJEN Intake system w/ Upper IC piping, GREDDY Type-S BOV, GREDDY Profec B Boost Controller, ESPELIR Cat-back exhaust, 3" HELIX Downpipe, 3" HELIX Test Pipe, APEXi S-AFC, AMS 660cc Injectors, Walbro 255lph Fuel pump, APEXi Turbo Timer, Boost Gauge (Psi), A/F Ratio Gauge, EGT Gauge, 19" PRIVAT Fahrens w/ NITTO 555 Tires, and 91 gas... oh yeah.. can't forget the Little Short Filipino dude that drives it.. now that will be a 13.0 sec car.. or lower..
I have dreams of getting a 12.6 or better, but I will be happy with a 12.9 if I don't see 12's I will get super pissed off and then attend driving school
Originally Posted by LostSoul Evo
f*ck that i think if i can get the launch right i can hit 12's. i wanna hit the 12's just for u john. on pimp gas at that
Originally Posted by IE Evo
Okay going from 14s to 12s is like going from 13 -11s. Not going to happen unless you get your car tuned properly and some driving lessons. Also you will need pimp gas not pump gas.I edited it for you already.
<----IE evo
[QUOTE=IE Evo]
i'm going to teach justin how to hit a 13 flat,since it's what i do best
yeah had to play catch up.
Joe still ownz you!You will never catch up. Joes on 19s and still beatin the brotha.
Originally Posted by evo81
i was getting 1.7 60fts with traps of 107=13.00.that was with exhaust,intake,mbc,fmic,fuel pump,dynoflash.good luck.your going to have to pull a lower 1.6 60ft to get 12s here with that set up
im good at what i do on the track. just tryin something different this last time out caused me to run bad times.
John I concur. Speaking from experience and such you are making sense. Shaving a 1/2 second is a biatch let alone 2 sec.
i'm really thinking it was the ACT cause i couldn't shift the way i use to shift like with the stock clutch.next time around it's the exedy twin for me
listen i aint tryin to hear that sh*t. i was using the wrong launch technique. i keep tryin to slip it when i should have just dropped it. my reaction time is great. i just didnt stage 2 of my races and i missed 2nd and 4th on my 2nd race. i can hit 13's easily, if i do my sh*t right. which i didnt do last time. i can give a flyin f*ck if no one believes i hit a 13.51 my first time out.
I believe you Justin.. the first time on the track I was Launching off through different techniques.. and I found my touch.. if I dont hit it right I'll bogg.. but I'll still manage to be in the 13s..
