FS: My 1990 Miata
Location: Where you come to vacation and go home on probation! Vegas!
FS: My 1990 Miata
Hey guys I picked up the car to build into a track car and to drive while my order for my 1M Coupe came in. I ended up canceling my order for my 1M and bought something cheaper for a daily driver and decided to go a different way as far as a track car is concerned.
So here is the deal.
-1990 NA Miata
-Clean Carfax - No Accidents
-5 Speed Manuel (with fairly new clutch - have paperwork)
-104,000 org miles (low mileage)
-Im the 3rd owner - owned by two women prior to me that where friends of each other
-OEM Hard Top
Mods:
-Brand New (maybe 100 miles) Rota Grids 16x8 +20
-Brand New (maybe 100 mikes) Falken RT615-K Tires
-Brand New (maybe 200 mikes) Flying Miata V-Maxx Coilovers with NEW NB -Upper Mount Conversion Kit
-Brand New Sparco Monza Steering Wheel and Hub (Mounted Today)
-Brand New Touge Run Front Lip
-Softtop removed as well as rear shelf carpet
-Trunk Stripped
-Rear Sway Bar Removed (still have it if you want to put it back on)
-Extended Suds Installed
-10mm & 15mm Spacers (new) - not installed
Maintenance Performed:
-When I got the car it had a bad oil leak from the Valve Cover Gasket & Cam Angle Sensor so I replaced both Gaskets
-Replaced all oil with Mobile 1 Full Synthetic and new oil filter
-Replaced Shift Boot (the rubber one that mounts to the body of the car) as it was cracked and leaking
-New NGK Plugs and Wires as the old ones where on their last legs
-New Hi Flow Air Filter
Extra Parts That come with the car:
-Stock Steering Wheel & Air Bag
-A 1.8L Complete Long Block (plans where to build this motor and S/C it)
-Extra 1.6L Rear End
-Extra 1.6L Drive Shaft
-Extra 1.6L axel & hub assemblies.
-Factory Daisy Wheels & Tires (painted matte black)
Photos:
For more info give me a call or e-mail me:
702-334-2494 or kderentz@gmail.com
Price: $4,500.00
-1990 NA Miata
-OEM Hard Top
Mods:
-Trunk Stripped
Photos:
Price: $4,500.00
FS[West]: FS: 2005 EVO VIII RR GSR w/ SSL Arizona
ElToro
For Sale - Cars For Sale
May 25, 2016 12:38 PM
bchappy
18
Oct 1, 2011 05:54 PM
