Any Tips on passing Cali Smog/Emissions?
If it's all stock like you say then putting the cat back in should be good. Also if your downpipe is aftermarket most places will want that changed back to stock as well. Other things they will look at are the intercooler pipes, blow off valve and vacuum lines(boost gauges and boost controllers).
mrfred
Jun 12, 2006 06:08 PM
