Utah Evos
Sticky Spring?
Okay never heard this before with the two years I have owned the suspension, but as of a few days ago my passenger front spring is making a popping sound when I turn the wheel. It does not do it when driving straight only turning. I had my friend sit in the car and turn the wheel back and forth so I could see what might be wrong. When the wheel is turned the spring will catch on the upper camber plate mount and jump/pop when the wheel is turning. I spayed some lube I had laying around the house on both the bottom and top of where the spring sits when compressed but it didnt do anything. Is there a better grease I should look at or is there something else I can do to fix this issue?
The front driver side does not have this issue. Also this is aftermarket suspension.
Yes it did change to Sunday (though I never remember it being on Saturday.) River Front Park I think was the location. Off of 106th south and like 300 west I believe. Can't remember exactly. Can't be hard to find either. Right by where Cars and Coffee is.
Sticky Spring?
Have you called them up to see what they say about the problem?
could be i suppose, i swear i met you at a honda meet in ogden i sold you a chipped p28 but it could of been jesten. I just remember the user name i guess
Tonight sucked for me. The best i ran was 13.1 i spun all through 1st gear and then i missed 3rd gear three times. My Wife got it on video, i just need to learn to download it on here.
Yea sam just call me to see where I am
Bring a 12mm open end to the bbq and I'll see where your clutch adj is at. If you want I'll make a pass in your car next time
I can't believe i added 6psi more boost and ran 6 tenths slower, plus the ****ing track guy's ran some cars through 3 times while i was still waiting for my second run, i hate that ****ing **** track!
