WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Boost taper with P2 flash
Old Apr 28, 2005 | 10:02 AM
xxxevo8xxx's Avatar
I have the P2 flash in my 03 evo. I does not always hold 20psi. Is this normal?
Old Apr 28, 2005 | 10:11 AM
Compjoc's Avatar
its supposed to hold 19psi.
Old Apr 28, 2005 | 10:13 AM
egui42's Avatar
Did you have it reflashed to hold at 20 psi? If not, it is supposed to hold at 19 psi. Check your bov, might be leaking or any other vacuum lines.
Old Apr 28, 2005 | 10:16 AM
xxxevo8xxx's Avatar
It will hold 19 -20 most of the time. But not always. It will taper to like 15-16. I have a type-s bov on and its not leaking.
Old Apr 28, 2005 | 10:25 AM
nebolic's Avatar
does it drop to 15-16psi and then climb back up to 19psi. This scenario happens when you mash it in 4th or 5th gear?
If so you probably have the older flash, the newer flash fixes that....
nebo
Old Apr 28, 2005 | 10:26 AM
alpha4lfe's Avatar
Correct me if I'm wrong but there will be times when boost tapers because regardless, the P2 is still controlling your boost through your ecu. So your ecu will not always let you hold your boost to redline if it doesn't sense the proper conditions. Also, the stock boost control solenoid is imprecise. If you want the boost to always hold, get a mbc.
Old Apr 28, 2005 | 11:56 AM
sir lurks alot's Avatar
Just spend the $50 and get a mbc.
Old Apr 28, 2005 | 11:58 AM
jbigelow's Avatar
WERD!!!!!!
Old Apr 28, 2005 | 12:08 PM
xxxevo8xxx's Avatar
Will a mbc work with the P2 flash? Would a ebc work to?
Old Apr 28, 2005 | 12:22 PM
TylerO@WORKS's Avatar
Most MBC taper off. The twin solenoid type EBCs seems to work pretty well. You may use with our flash if you like.
Keep in mind that the stock solenoid is an electronic boost controller. WORKS controls boost by programming the ECU. There are certain times when the ECU will decide to pull boost, timing, and dump fuel (among other things). This is for safety and long term reliability, one of our main goals. We left the safety maps and functions untouched in our flash to keep that margin of safety you won’t have with an MBC or EBC.
wingless's Avatar
you payed the extra buck to intelligently control boost through the ECU...use it. The ECU constantly monitors sensor readings and is there to to switch maps, boost and timing as close to the edge as possible without damaging the motor.
The P2 will further push the timing and fuel an edge closer to destruction and give you more boost while still retaining the factory safe guards.
Some people swear by MBC's, but mostly drag racers running in tightly controlled circumstances with purpose built set ups. On the street in a climate with seasons MBC's can really suck and are generally a step back in evolution.
Old Apr 28, 2005 | 01:16 PM
xxxevo8xxx's Avatar
so if i get a 2 stage ebc and install it with the p2 flash, do i net to remove the boost solenoid? will the p2 still work right?
Old Apr 28, 2005 | 01:21 PM
alpha4lfe's Avatar
The ebc/mbc you get will replace the factory solenoid. If you have questions regarding the P2, you should give Works a call, they are readily available and are always welcoming questions you might have.
Old Apr 28, 2005 | 01:25 PM
KazzEvo8's Avatar
Is there an EBC Works recommends with the P2 flash?
And what is the difference between today's P2 flash for an '03 on 93 octane and the flash from a year or more ago?
Thanks.
Old May 2, 2005 | 04:32 PM
Jamie@WORKS's Avatar
Thanks.
WORKS recommends the P2-controlled factory BCS
There may have been some minor tweaks to the flash in the past year, but nothing significant to warrant a reflash at this point (unless your supporting mods have changed).
