Genuine FQ-400 Wheels
WORKS has managed to acquire these extremely rare wheels. Don't miss your opportunity to obtain this set for yourself!
http://www.worksevo.com/store/produc...roducts_id=220
uhhhh..
Those are $196/each wheels kiddies. $784 total.
Team Dynamics Pro Race 1
http://www.frisbyracetire.com/pro_race_1.htm
Lancer Evolution VIII MR FQ400 upgrades:
Custom built Garrett GT Dual Ball bearing Turbocharger
Owen Developments custom manufactured cast Stainless Steel Exhaust Manifold and Exhaust Elbow
Omega Forged Pistons
HKS Forged Con Rods
HKS 680cc Injectors
Zytec ITP116 High Pressure Fuel Pump
HKS 1.6 mm Steel Head Gasket
Motec M800 OEM ECU
HKS Iridium Spark Plugs
Jan Speed High Flow Sports Cat
Alcon competition derived 240 mm high clamp mode, heavy duty clutch complete with Cera-metallic 6 paddle sprung centred drive plate
HKS High Strength Head and Big End Bolts
Alcon Mono6 Brake Kit incorporating Monobloc 6 pot road caliper with 343 mm curved vein Disc on a Aluminium mounting bell assembly with Ferodo DS2500 brake pads
Ralliart Aero Mirrors
Carbon Fibre Front Lip Spoiler
Carbon Fibre "Sharks Tooth" Rear Vortex Generator
PIAA High Performance Light and Wiper Upgrade
Gloss Black Team Dynamics Lightweight Alloy Wheels
Driver Training Course
http://www.fast-autos.net/mitsubishi...ishifq400.html
Why are you asking $2,400? Am I missing something?
HKS Forged Con Rods
HKS 680cc Injectors
Motec M800 OEM ECU
I don't know why people over here are so enamoured with the FQ400....maybe it's because their isn't a USDM version and it has a certain rarity value and cache.
If you search around on the UK's "Evo" website (www.lancerregister.com) for people who actually own one, many of them are having problems and are unhappy with the performance. There's also a very interesting & revealing performance comparison of the FQ400 and FQ340 and guess which one came out on top....it wasn't the FQ400.
Also, as previously stated the wheels are el-cheapo (relatively) TDR Pro Race 1 cast wheels (around 19.8 lbs for the 17x8" FQ400 wheels) which pale in comparison to the USDM "MR" BBS forged wheels (lighter and much higher quality).
The only difference with the FQ400 wheels (over standard TDR Pro Race 1 "flat black" wheels) is that they're painted a gloss black colour......that's it.
Oh, and you will need a new set of lug nuts; the OEM ones won't fit. Also, they're not hubcentric but do come with a plastic centering ring.
If anyone's interested the Mitsubishi UK part number for the Mitsu logo center caps for these wheels is SR010245....don't know whether any US vendors are selling these.
abcdef,
basically the fq-400 is just like many of our cars under the hood, except they use THE MOST expensive parts to the get the job done i.e. the MOTEC ecu which costs somewhere around 10 g's. A big difference tho is the aftermarket pistons, rods, etc. This is something that most people don't do unless they have a HUGE turbo bolted on, and i mean like 600+whp. Other than that i believe the cams are even a set of HKS 264's. But to answer your question, to get the same results as an FQ-400 you dont have to spend what they did, you can do it for under 10K...WITHOUT a warranty
Vroompsh,
Thanks for you response. I mean it's just out of curiousity because can't the stock enternals already handle that kind of power? I also found the link that razorlab posted to be an interesting read. Does anybody here happen to know what kind of turbo is ran on the FQ-340? Alright this will be the last post that's off topic. Thanks.
Originally Posted by abcdef
Vroompsh,
Yup, the 340 runs the OEM turbo.
It doesn't have many mods; remember, this is 340 crank hp, not whp, so it's only around 40 hp more than stock). I think they put on a different (HKS ?) exhaust, possibly an intake and do an ECU re-map. That's about it.
FYI.....in a similar vein, the FQ400 is 400 crank hp, not whp. On a Mustang load-bearing dyno, it would probably only register around 320 whp.
OMG, I'm in love!
