P2 users in San Diego
Originally Posted by macster
Does any one in San Diego have a P2 installed?
m~
m~
Originally Posted by TylerO@WORKS
Yes, a lot of people do. Check www.socalevo.net
Thanks, the reason that I'm asking is that I haven't found the "how to" instructions on your site and I want to walk thru it before I do it.
m~
Tyler
m~
m~
contact Rob at www.myevostore.com ...
Good luck!
BTW, I got the downpipe and brake lines today. Next week I will probably do the ECU, Stealth muffler and the throttle body. The Downpipe doesn't look too bad. One scuff mark at the end where it connects to the O2 housing. The only complaint is that there was no parts list of what was included with the DP. And I'm assuming that this doesn't get a doughnut gasket. Anyway, I will do a search.
m~
Thanks
m~
m~
Originally Posted by Jamie@WORKS
The 70mm DP utilizes the OEM donut gasket. You should have gotten a hardware kit that includes two bolts for the housing and two nuts for the hangers. An OEM gasket should be in there for the connection at the cat as well. Let us know if you have any other questions.
How about shipping instructions for the ECU? So that I can get P2 installed. I will check your web site and if I can't find them, I will give you a call in the am.
Uhhh, I found the shipping instructions. I will be calling you guys in the am.
m~
Originally Posted by Spec'd
Schaweet.
I just sent off my ECU. I am ordering the following Works items right now:
- P2
- Stealth muffler
- Drop air filter
- 70mm Down pipe
- brake lines
Then I will finish installing the amps for my audio system. I have to make it neat and cut out the mounting board and etc. So I'm in no rush.
m~
Okay
I had the following installed today:
I had to send out my muffler to get converted to a "Stealth" muffler. Hopefully, I can get it back by this Friday, but if not, next week will "Works."
m~
- Works P2
- Works brake lines
- Works Air filter
- Works down pipe
I had to send out my muffler to get converted to a "Stealth" muffler. Hopefully, I can get it back by this Friday, but if not, next week will "Works."m~
My Works P2 Flash Dyno Results
I didn't do a baseline dyno. So who knows what I was putting down stock. Anyway, the dyno session was done yesterday at Tuning Technologies. I did 3 pulls with AFR's and it cost me a $100.00. The mods to the car are;
Works P2 flash
Works High flow air filter
Works 2.5" Down pipe
Works Stealth Muffler
Results:
Props to Tuning Technologies for good service and explaining to me how read the results and the Works crew for providing good products.
m~
Works P2 flash
Results:
- Run 1: 272.82 WHP, 291.43 Torque
- Run 2: 268.01 WHP, 281.07 Torque
- Run 1: 275.84 WHP, 272.86 Torque
m~
