Brake lines - what's up WORKS?
As one of the people who experienced this failure, I've been in close contact with Pete and Kirk about this issue. I believe they are treating the matter with all the seriousness and priority that it merits; my only criticism would be that they should be more communicative about it.
I guess what everybody wants to know is, is there a fundamental problem with the TKS brake lines, and that's not an easy question to answer.
In the meantime I'd encourage anyone who tracks their cars to closely inspect their brake lines--WORKS or otherwise. Note that this same failure has occurred with stock brake lines as well; if you have any doubt as to the condition or safety of your brake components, you should repair/replace them immediately.
Thunderhill 12/11- results from testing & inspection:
After tracking my Evo, Oliver's Evo and the Time Attack Evo for (5) 30min. sessions, we found no issues w/ regards to the brakelines. We are continuing the research and will keep you posted on further developments.
If anyone has more concerns please feel free to call us anytime during business hours.
Sincerely, Kirk
415. 641.9675
Sincerely, Kirk
415. 641.9675
Any update? Or is this just going to be swept under the rug? Instead of taking some car to the track with them you should be inspecting the ones that failed, find which batch they came from and see if they too have the same fault. Taking a random sample is not good enough guys. Do you even know why they originally failed? I've read the post on NorCalEvo with your vauge explaination, but nothing pointed to "it was this piece that failed because of this".
hmmmm, I have these lines and they have been great. I went to over 20 track days last year alone.
I dont see anything wrong with them and they look like new. Anyways the bimmer will be racing this season so no more EVO track time
keep up the good work Works
Originally Posted by RT
^ Do you have these brake lines on your Evo? Do you know of any problems with these brake lines anywhere else in the country?
Anyway I look forward to hearing from WORKS about what they've found out so far.
Isolated? I didn’t say it was isolated, what I really wanted to say was “you drag your feet more than Fred Flintstone Tam!” That’s what was really on my mind!!!!
(j/k bud
(j/k bud
Originally Posted by evo8silver
do u guys know of cases when the brakelines coating "teflon" peals off? cus its happened to mine thanks
Is this what your Works lines look like?
http://www.norcalevo.net/forums/viewtopic.php?t=6054
Personally, I think if your brakes are getting hot enough to melt the teflon coating over the brake lines, you are at risk for a brake line failure. Both of my brake lines that failed showed damage/melting of the teflon coat.
take it for what its worth. just my observations/opinion
I have these lines also... Installed them with my friend, and took them to a 3 day track event. I have had them about 1 year now... Zero issues. I will inspect them tonight for wear and tear.
hopefully this is an isolated issue...
becareful everybody
becareful everybody
Is the WORKS brake lines available yet????
When will it be ready?
Please PM me with update info...
Only posted here because it takes awile before PMs are returned....
If discontinued please let me know ASAP, so I can go a different route
thanks
R/S
thanks
R/S
WORKS New lines
Currently, we have completed the new prototype for the WORKS (WRP) brakelines that are designed specifically for track use. These new lines will be out within 8 weeks.
We have our current TKS lines in stock that are recommended for street application. That being said I have over 27 track events on my set w/o any issues.
I will put in my order tonight....thanks
