WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Stealth Muffler the same w/ IX
Old Apr 25, 2006 | 03:05 PM
Jamie@WORKS's Avatar
The O2 housing and 76mm DP are in stock and the redesigned 70mm DP should be available in about a month.
Old Apr 25, 2006 | 03:17 PM
Karash's Avatar
Ok I did not know since it says out of stock on your website. Thanks!
Old Apr 25, 2006 | 03:35 PM
Fixed
Old Apr 25, 2006 | 03:41 PM
Karash's Avatar
Since you are online right now....any combo deals???
Old Apr 25, 2006 | 04:21 PM
Yes, call us for details
Old Dec 11, 2006 | 04:31 PM
UpstateEVOVIII's Avatar
Just keep the stock cat-back and get a downpipe and high flow cat. The cat-back is essentially the "bling" section of the exhaust anyway. Power gains for cat-backs are overrated IMHO.
Old Dec 11, 2006 | 05:12 PM
DEV1N's Avatar
+1
I partially agree with that statement. I am running a "test pipe" with the stock down pipe and stock cat back. I would say the gains of a "test pipe" alone is greater than any aftermarket cat-back exhaust system today.
Now later on down the road if I decide to upgrade for the "bling" factor I would go with something titanium and used/2nd hand off course
Old Dec 12, 2006 | 02:18 PM
The muffler is what provides the restriction in the cat-back. There's the flapper in the VIII and just a few mediocre holes in the IX that force the majority of the gases through a convoluted pathway before they're allowed to exit. Good for noise suppression, not so good for flow. Retaining the original IP isn't going to rob you of a significant amount of power until further along with modifications.
Old Dec 6, 2007 | 01:20 PM
Rod Munch's Avatar
Resurrecting Ancient Thread
Has anyone tired just drilling out the baffle in the IX muffler? Sounds like it would be pretty easy ....
Old Dec 7, 2007 | 04:51 PM
Have you tried sticking a drill inside the inlet pipe? If it could be done, we'd be doing it. However, the "right" way to do it is to plasma cut, weld, grind, paint and polish. Everything else just hasn't come out properly.
