WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
bad flash maybe
Old Dec 23, 2005 | 07:49 PM
carbonevo8's Avatar
updated its fixed but no p2r
ok well I fixed the problem come to find out it was the idle screw needed to be screwed in. But the p2r doesn't seem to be working it wont hold at 6000rpms. Oh well I'll have to talk to works about that. Thanks again guys for all the help
Old Dec 23, 2005 | 07:53 PM
Compjoc's Avatar
I dought it's a bad flash. Do you have the 2-stage rev-limiter? Maybe your clutch pedal sensor is bad and therefore engaging the lower rev-limiter in gear.
Old Dec 23, 2005 | 07:57 PM
carbonevo8's Avatar
yes its a 2 stage rev limiter. It's set at 6000RPM though not 4800RPM. Could it be anything else? Also it never did thid before the p2r. I had the p2 at first then got the p2r and now it does this.
Old Dec 23, 2005 | 08:05 PM
Compjoc's Avatar
Does it happen at 4800rpm in every gear or do the rpms vary?
Old Dec 23, 2005 | 08:11 PM
carbonevo8's Avatar
same in every gear and in nuetral and its always at 4800rpm
Old Dec 23, 2005 | 08:49 PM
Compjoc's Avatar
It's gotta be something to do with the 2-stage rev-limiter. All I can really think of is to check out the clutch pedal sensor to see if the rod is moving freely in and out. If thats fine you should call Works and see what they think.
Old Dec 23, 2005 | 10:11 PM
badhabit90's Avatar
Cool
Originally Posted by carbonevo8
Well guys I ran into a big problem and need some help. Heres my synario I have a 03 evo and I installed and WR turbo w/ high pressure actuator, FIC 750 injectors, Works 65mm throttle body, Works 3inch 02 housing, Agency Power fuel rail, and Works BOV. I put the stock air intake back in with the works air filter. I had everything tuned by works I have a custom P2R flash. So heres my problem when the car is in gear or in neuteral it will only go up to 4800RPM and then it hits either a rev limiter or a fuel cut I can't tell I personaly thought they were the same. I checked everything to make sure everything is hooked up and it looks good to me. Is there something that I could have missed? Could the flash be bad? I haven't adjusted the throtlebody at all yet either so it idles at around 1500RPM. Any help would be great thanks guys and have a merry christmas.
I posted this in 2 places because not everyone reads the works forums
is the MAF plugged in all the way?? is the TPS plugged in all the way?? what is the reading for the TPS at WOT?? is it calibrated correctly?? are the fuel injectors plugged in correctly?? how is the power otherwise?? does it pull to 4800rpms or just feel sluggish?? boost leak??
check everything one more time just to be sure....
Old Dec 24, 2005 | 09:42 AM
carbonevo8's Avatar
ok I checked everything to be sure and its all pluged in and seems fine. The car is a total monster it really starts to suck you into the seat but when it hits 4800RPMs its hits the limiter. I called works on friday but nobody answerd. I'll probably have to wait till next week to talk to them if I'm lucky. Everything seems to be fine untill 4800rpms
Old Dec 24, 2005 | 10:15 AM
JCEvo's Avatar
does that happen before or you said that you just change something with air filter,right??how about BOV? Did you took out BOV and installed it back? Did you check that is on the right direction??
Old Dec 24, 2005 | 10:20 AM
carbonevo8's Avatar
yes the bov is in the right direction. It is the stock intake with the works filter. The bov is works bov. I can try changing it back to the stock one to see if thats the problem but I doubt it is.
Old Dec 24, 2005 | 03:15 PM
Compjoc's Avatar
Did this problem just arise out of nowhere or has it always happened since the custom tune? Have you tired reseting the ECU (unplug the battery for 15 min.) ?
Old Dec 24, 2005 | 03:44 PM
carbonevo8's Avatar
this problem just started after I got the updated flash befor that the flash was fine.
Old Dec 24, 2005 | 04:31 PM
badhabit90's Avatar
Cool
Old Dec 24, 2005 | 07:51 PM
carbonevo8's Avatar
It's fixed now but the 2 stage rev limiter doesn't work but I'll have to talk to works thanks again for all the help guys
Old Dec 24, 2005 | 08:33 PM
badhabit90's Avatar
well, what was the problem???
