WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
p2 flash
Old Dec 24, 2005 | 04:30 AM
tkeirin's Avatar
p2 flash
sup works and everyone..........just a quick question..............can the p2 flash for the 05 evo 8 allow the boost to spike to 2.03 bar (approx 29 psi)?
Old Dec 27, 2005 | 01:14 PM
Alias's Avatar
As quoted by Jamie from his Boost "Control" Flashes sticky:
"In theory, yes. Although I wouldn't recommend trying to squeeze 30 PSI out of the stock setup Provided there are supporting mods that are able to run this boost within their design parameters, WORKS could set the PSI accordingly using our software/boost hose.
We haven't used any aftermarket solenoids. Frankly, we haven't seen the need to.
The WORKS boost hose assembly allows us to use the software to provide the control others are lacking. Exactly what is done to allow this is proprietary information that our Engineers won't be giving up.
WORKS doesn't intercept/alter any signals. What the ECU sees with the WORKS software is the same as what it sees with OEM software."
Old Dec 28, 2005 | 08:40 PM
tkeirin's Avatar
thats not wat i'm asking about.
Old Dec 28, 2005 | 10:30 PM
Evil EV0's Avatar
What your saying is you want it to spike to 29psi for a second then go back down? I dont know if that is possible or not, but I dont see why you would want it to do that. I have heard of some flashes where the boost rises as rpms increase, but you need to sign a waiver
Old Dec 29, 2005 | 01:49 PM
tkeirin's Avatar
actually i don't want to have to boost to spike to 29 psi. wat i'm saying is with just the p2 flash (still set @ 19 psi), would boost spike tat high on it's own.
Old Dec 29, 2005 | 09:18 PM
Evil EV0's Avatar
Well I know my car doesnt at all...Mine is set at about 21-22 psi and according to my Defi boost gauge thats all it hit's it doesnt spike to no crazy #
Old Dec 29, 2005 | 10:01 PM
Compjoc's Avatar
I have a 03 Evo and it used to happen to me but not anymore (updated flash). It was very rare (only in 5th gear going WOT at low RPM in cold weather). I'm not positive it was 29psi because my boost gauge only reads up to 25psi but it would spike well into the high 20 psi's.
Old Jan 17, 2006 | 06:08 PM
Timujin's Avatar
Ditto,
Stock my 05 boosted higher and was more variable compared to after the P2. After the P2 I could still boost just under 25 only under WOT in 5th gear at 80+MPH.
