Sound Clip for ABM?
[QUOTE=kirk@WORKS]
If you are planning to run a HFC or a resonated test pipe you will need the ABM.
I currently run the complete WORKS (3 inch) 76mm system w/ the WORKS HFC and ABM.
QUOTE]
That't the setup I'm planning to get eventially, so if you could get a sound clip, then it would be much apreciated.
QUOTE]
I have the ABM ONLY with everything else stock, I picked up a number of whp, and it's not that bad sound wise. . .around town it's hardly noticeable, when I get on it, it's there, and hwy drone is non-existent. . .Now if I were to the the O2Housing+DP+IP, it would be LOUD as hell. . .but after looking at the stock exhaust, I realized the real restriction is the stock muffler, it REALLY slows the exhaust velocity down at higher rpms, so I kept the stock ID (2.5") which opens to the WORKs ABM (3"ID), and get the sort of best of both worlds. . .I don't think I justify the loudness for another 10-15whp. . .flash+cams are more worth it in that case. . .I could post a vid of my setup if you'd like. . .
shiv please post a vid of that setup, im waiting to order the EXACT same thing!!
how badass is that slash cut abm!
haha, Okay guys, will do for sure. . .I'll post a vid somehow. . .someway, it'll be sexy. . .it's well worth it. . .next in line for me will probably be o2, dp, a flash, and that should put me at 280ish. . .
Originally Posted by mmoranda
Here's a little teaser. Please no comments on my auto x skillz.
this is with works 70mm dp and no cat and works resonated mid pipe
http://www.norcalevo.net/gallery/alb.../MarshallI.avi
Finally, sound clips of WORKS ABM-Performance Package 1
Hey guys, finally got around to taking videos (large ones!) and uploading them onto my site. . .
My setup is in the signature, but in case you're too lazy, I have the WORKS ABM and Hiflow air filter, got it for around $400??
I dynoed with these mods about 10-15whp above a stock EVO, so these are true gains.
It's not very loud at all, I took an interior shot dirivng around town and then revving at a stop sign:
ABM interior
Then I went to a secluded area and videotaped the ABM from the side of the street, as if you were walking by:
Walking by
Then finally I decided to let y'all know what it sounds like from behind, which is where most cars find themselves after I've burned them:
From the rear
THey are all relatively large, so if you want to play them over and over, please right click save as!
For $400, the package does deliver some goods for sure, I just wanted a more aggressive exhaust, a quicker spool, and of course some power.
Obviously getting a flash for $175 would be the best bang for your buck, but at least with this performance package, you WON'T be voiding your warranty.
Enjoy!
ABM interior
Walking by
From the rear
Enjoy!
And my dyno plots with these modifications
So when I was looking at that video (walking by), I noticed how RICH my setup is (factory of course) and realized I never posted my dyno plots, so here y'all go
Notice how rich it is up top, and how pathetically my boost drops off after 5k rpm. . .there is a LOT of power to be had here. . .
