WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Boost question.
Old Sep 9, 2006 | 04:27 PM
ak47po's Avatar
Boost question.
I just got a WORKS P2 mail in flash for my EVO IX with the following mod's TBE,Intake,255 Walbro and downpipe.The max boost i get at WOT in third gear on the stock boost gauge is 1.0,could it be the stock BOV not holding boost.Any suggestion's from someone at WORKS would be helpful.
Old Sep 9, 2006 | 06:04 PM
xtremeIX's Avatar
Boost Leak...?
Have you checked for boost leaks?
Old Sep 9, 2006 | 06:42 PM
Smoothgangsta's Avatar
Double check to make sure the boost lines are properly attached back to the solenoid and off the wastegate/turbo and if you removed any of the intercooler couplers make sure those are back on properly and secured tight.
To me it sounds like it's something with the boost lines.
Old Sep 9, 2006 | 06:52 PM
ak47po's Avatar
One thing that did happen when i changed the boost line i broke one of the plastic stem's on the BCS that the new hose connect's to and had to epoxy it back together.Everything else is tight.
Old Sep 10, 2006 | 12:00 PM
Get rid of the broken solenoid and replace it then. I am surprised you broke one of those stems...they are pretty strong. Find out what a new solenoid will cost and replace it.
Old Sep 10, 2006 | 12:06 PM
ak47po's Avatar
$54.00 from Mitsubishi,it's on order.
Old Sep 10, 2006 | 04:44 PM
I am pretty sure once you replace it that will resolve the boost issue. If not, disconnect the negative terminal for 5-10 minutes to clear the ECU and reconnect and go drive a few miles to see if it gets beyond 1bar of boost.
Old Sep 10, 2006 | 04:50 PM
ak47po's Avatar
I'll give it a try thank's for the info.
Old Sep 10, 2006 | 05:47 PM
ak47po's Avatar
Anyone else beside's markeddy.
Old Sep 11, 2006 | 02:11 PM
20psiMR's Avatar
Its the solenoid. I would bet money that when you epoxy'd it, it closed the hole and its not getting air thru that inlet. Your running wastegate boost right now, thats it.
Old Sep 11, 2006 | 04:27 PM
Jamie@WORKS's Avatar
I'd agree with that... Airflow is critical through that line and its connection points and even minute alterations can vary the results significantly.
Old Sep 11, 2006 | 04:30 PM
ak47po's Avatar
Thank's jamie i pickup a BCS tomorrow hope it make's a big difference.
