WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
WRP Exhale HFC fitting
Old Apr 4, 2007 | 08:48 PM
Huy's Evo's Avatar
does the WRP Exhale HFC fit on a evo 9 with stock exhaust and dp?
Old Apr 5, 2007 | 05:08 PM
EuroEclipse's Avatar
Yes it does
All of the WORKS exhaust products are designed to fit to the stock equipment.
Old Apr 5, 2007 | 05:35 PM
EviL_IX's Avatar
it will fit but you have no where to put the o2 sensor.
Old Apr 10, 2007 | 10:28 AM
MRgraphite's Avatar
Exactly, which has three solutions or maybe more and I am leaving them out.
1) Best option-get an aftermarket catback-Yay power!
2) Hope one of your Evo VIII buddies has his intermediate pipe for you to use or obtain one by some other means.
3) Weld a bung into your factory piping
Old Apr 10, 2007 | 03:25 PM
tirbolag9's Avatar
is there a specific direction which the hfc flows? (i.e. shiny side facing ground or dark side facing the ground). there is no indication which is top or bottom or which way the cat flows.
reason why i'm asking is that i got a used works hfc and before trying to mount the hfc, i want to weld an 02 bung on the back end of the hfc pipe.
any suggestions to what angle i should weld the 02 bung?
i apologize for all the questions, just too lazy to go under the car right now.
tia!
Old Apr 10, 2007 | 09:03 PM
MRgraphite's Avatar
Shiny side should be up. Also, when you are under the car, the flanges from the downpipe and the catback are angled, so I believe it can only fit one way.
I don't think the angle matters, but I would put the O2 sensor in the intermediate pipe of the catback, less heat so it will be easier to remove the sensor if you are switching out parts, then when you get an aftermarket catback that has the bung in it, you can just put the sensor in that.
Honestly, I would just wait until you have atleast an aftermarket catback to install the HFC, you are really not going to gain anything from just changing out that one section.
Old Apr 10, 2007 | 09:12 PM
tirbolag9's Avatar
i have the garage hrs exhaust and it didn't come with an 02 bung. and i don't think i'm going to put one either the exhaust is too pretty to weld a bung on there!
the hfc i have has one side of the shield aluminum colored and the other side of the shield is dark/tarnished colored. i guess the side where "off road use only" is printed should be facing the ground?
Old Apr 10, 2007 | 09:57 PM
Check the times that Dan Bajalis put down with his Evo IX. Flashed, Exhaust Cam (since the mivec cams weren't made yet), 3" downpipe, test pipe, stock catback, stock clutch, stainless clutch line.
So it's a little hard to say that there isn't much to be gained without a catback. But, then again, he's an insane driver.
Old Apr 11, 2007 | 09:24 AM
TylerO@WORKS's Avatar
The WORKS Exhale IP ( http://www.worksevo.com/store/produc...products_id=52 ) has a bung for the O2 Sensor and will bolt right up to all your other stock or WORKS exhaust components
Old Apr 11, 2007 | 11:23 AM
Jamie@WORKS's Avatar
The HFC will only fit one way front-to-back. (It could still be bolted up incorrectly, but the cat itself would be perpindicular to the ground rather than parallel.) It can be rotate 180* so the stamp is up or down, but should be marked as to what side is the bottom.
Old Apr 11, 2007 | 01:34 PM
tirbolag9's Avatar
hi jamie thanks for the response!
the hfc does not specify bottom or top. just only the "off road use only" stamp. i will have to assume that is the bottom? i got this hfc used and i'm planning to weld an o2 bung on it...although i have not yet mounted the hfc.
to be honest, i don't want to lift the car up to check...which explains that i'm trying to take the easy way out by asking. but i'll the bullet and lift the car up and match the flanges and determine where to weld an o2 bung.
Old Apr 18, 2007 | 05:08 AM
EvImVictim's Avatar
Question
Bump for an answer. Which is the inlet and should the shiny side be up?
Old Apr 18, 2007 | 05:06 PM
i believe it's the "off road use only" side up. that's how mine is.
Old Apr 19, 2007 | 09:51 PM
tirbolag9's Avatar
actually, "off road use only" should be facing the ground. i finally test fitted the hfc and it only fits one way as per jamie.
those with a ix...if you want to weld an o2 bung on the hfc weld a bung in the same angle as the o2 bung on the original cat----that's if your catback does not come with an o2 bung like my garage hrs!
Old Apr 20, 2007 | 11:19 AM
*shrug* had it put on at the shop. oh well.
