Works Rear Sway Bar *Possible Issue??*
I helped a buddy install a Works Rear Sway Bar on his Evo 9... we set it on the middle setting and it looks like it's basically touching the rear cross member... would this pose a problem other than the occasional clunking from bumps?
The bar fits pretty snugly in there, but it shouldn't actually be touching. You should be able to slide a piece of paper in behind the bar and it should clear. As long as there are no rattles or buzzes coming from the bar you should be fine.
-Bill@WORKS
-Bill@WORKS
