WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
WORKS Official 93 Octane Brain Flash Dyno Plots
Old Jun 24, 2003 | 04:51 PM
Zeus's Avatar
I ment post them over each other so the results would be a little clearer... I thought it would be a pretty safe assumption that both runs were your car/same dyno etc.
Old Jun 24, 2003 | 05:02 PM
DavidV@WORKS's Avatar
Different scale on the graphs.
-- DavidV
Old Jun 24, 2003 | 05:16 PM
Zeus's Avatar
Old Jun 24, 2003 | 05:38 PM
BadBoyBeltran's Avatar
David,
I am currently in Texas right now. How much is it with shipping/hadling/reflash to Austin? Also, can you give us the COMPLETE specs of the WORKS reflash such as max RPMs, max boost, AF ratio etc without disclosing too much to the competition?
Thanks! I'll be ordering one this week!!!
STI
Old Jun 24, 2003 | 05:50 PM
BOOYAH1369's Avatar
In Timeout
Posted graphs and link on Team SLAM. You might wanna check it out!
Old Jun 24, 2003 | 05:54 PM
Zeus's Avatar
More caliSPAM!
Old Jun 25, 2003 | 03:14 AM
The Barst's Avatar
A graph with all the numbers together would be nice, can't you change the scale to fit?
Old Jun 25, 2003 | 03:26 AM
ghostrider's Avatar
Originally posted by BOOYAH1369
3HP is plenty. Every little bit WORKS can squeeze outta our USDM SOHC four-bangers is appreciated.
I do believe this is for the Evo, not the Lancer.
Old Jun 25, 2003 | 06:37 AM
USP45's Avatar
I too would be interested to see an overlay of the two graphs once put to scale. Hey David, would the stock Evo loose that much HP when running 91 to 93? I have read that it is pretty sensitive, but man that is a leap! Anyway it looks pretty good. I would think that if there is such a difference between the stock numbers that from the factory the Evo has some very aggresive timeing.
Old Jun 25, 2003 | 06:46 AM
newevo8's Avatar
Nice numbers. Is this situation with the new ecu perametors only? Are there any other modifications that will be needed to acheive the 246 hp?
BIG ? Will you be installing new cams in the future? like say something along the hks 272 or 264 or maybe your version?
Old Jun 25, 2003 | 06:48 AM
newevo8's Avatar
I agree
Old Jun 25, 2003 | 06:56 AM
BLKEVO8's Avatar
Originally posted by RaX
What about 93 octane with lots and lots of ethanol in it?
ethanol is bad in the sense that it raises the BTU's your better off boosting octane with toulene or xylene cooler burning and its one of the components of gas. 10% mix gives roughly a 2 octane increase. 92 octane with 10% goes to like 94.23 octane. ethanol is great for the enviroment though clean burning comes from corn so supports farmers but not good for turbo high performance cars.
Old Jun 25, 2003 | 07:41 AM
Zeus's Avatar
OT
Who has used xylene personally?
Old Jun 25, 2003 | 08:13 AM
BLKEVO8's Avatar
I have a drum coming to my house it has a R+M rating of 117 octane I have checked into the fuel lines and pump and they are more than adequate to handle up to 40% mix of aromatics which already exist in Gasoline. Adding only 10% will be completly safe its only when you start going in the overall 50% and above that you may start getting in to the danger zone. It is the cheapest bang for the buck on octane boosting its the same stuff they try and push off in those canned octane booster they charge $8 for 16oz or so and only give a .2 boost. Read this article very good. http://www.elektro.com/~audi/audi/toluene.html
Old Jun 25, 2003 | 08:24 AM
boostedwrx's Avatar
I use Cenex 94 octane. It comes from the Widwest and contains 10% ethanol. Car runs smoother and pulls harder with it than the standard Chevron Blue 92!
