WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Ohlins Instructions
Old Jan 25, 2010 | 08:11 AM
chu's Avatar
chu
Ohlins Instructions
Hey Guys. I'm finally upgrading from my Works Ride/Bilstein setup to some Ohlins/Hyperco/Works. I didn't get instuctions on assembling and installation, dont ask. Could you provide a link or something? I'm unsure what the proper method is for tightening down the top nut on the rear coilovers without having the shaft spin.
Thanks,
Chu
Old Jan 26, 2010 | 05:51 AM
chu's Avatar
chu
Bump for some insight...
Old Jan 26, 2010 | 10:00 AM
spool_sample's Avatar
The best way is to use a strap wrench to hold the shaft in place, then torque the top nut down. Don't know the torque spec, though, maybe someone else can provide that.
The quick and dirty way is to give it a quick zap with an impact, and that should be enough, although you will want to check it periodically. Don't chug on the top nut with the impact for more than a split second or so, or else you risk tearing up the seals inside the shock. I usually don't recommend this, but it works if you need to put the car together to make the trip to get a strap wrench.
Old Jan 28, 2010 | 09:28 PM
Goch's Avatar
Works is clearly not interested in their own forum anymore.
Old Jan 30, 2010 | 09:41 AM
chu's Avatar
chu
^^^Starting to be pretty obvious!
Old Jan 30, 2010 | 04:59 PM
DaveGSR's Avatar
This is just sad because I really like WORKS products.
Old Jan 30, 2010 | 05:19 PM
smack_evo's Avatar
Thanks,
Chu
i thought it was done the same way as the fronts. it's been a while since i had any of my ohlins.
from what i remember you unscrew the collar of the adjuster. once the adjuster is off then you can get to the hex inside the shaft. use a hex wrench to hold the shaft from turning and a box wrench to tighten up the nut. once tight just screw the adjust back on and you're ready to go.
ps. there's a little spring under the adjuster in the shaft. make sure you don't lose that.
it shouldn't be a problem if you are pulling the adjuster off once the shocks are bolted in the car but if you're doing it out of the car then just make sure to keep an eye out for it so it doesn't fall out while on the workbench or something.
hope this helps
muster
Jan 30, 2016 09:08 PM
chu
15
Nov 23, 2015 11:35 PM
KamilEvolution
Jun 20, 2015 04:51 AM
formerSTIowner
22
Mar 20, 2015 10:04 AM
chu
Nov 14, 2012 06:10 PM
