I need cams & Water injection?
Whats the time frame Dave? I want more power. I'll drive up and have you install them if they will be ready soon. All I keep hearing is just around the corner. I want to go with WORKS but can't continue to wait without a legitamate time frame. I know what you will produce will be top notch but I'm getting very itchy. My P2 is awsome, o problems in every type of weather. 0 fuel cut etc. Perfect.
I want 50 more hp soon. ZO6s and 911 turbos still giving me problems.
Give us a reason to wait and not go with other options.
I could care less about an intake and already have a 3" exhaust as do many others.
Thanks
Re: I need cams & Water injection?
Thanks
Thanks
-- DavidV
From other WI applications in which I have been privy the "effect" of WI is useful in high boost apps were either the fuel system is taxed or is puprosfully run lean. Those apps that dont run lean fuel settings actually suffer from the WI. Is works possibly going to use the WI to run a bigger turbo (past the limits of the factory fuel system) as a means of a buffer? Only on highly modded/ high boost cars were the "effective octane" that the WI system us useful. Check out pestos project for the types of apps WI is successfully used
Originally posted by boomn29
For those of us a bit slow - what do upgraded cams really do??
