WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Works Ip ?
Old May 19, 2004 | 10:39 AM
BatEvo's Avatar
Works Ip ?
Anyone know the weight of the WORKS 70mm resonator less IP and the OEM IP?
Rick
Old May 20, 2004 | 12:22 PM
TylerO@WORKS's Avatar
WORKS: 7.6lbs (70mm)
STOCK: 11.7lbs
Old May 20, 2004 | 12:35 PM
caymandiver75's Avatar
does WORKS even have the exhaust components in stock!?
Old May 20, 2004 | 02:38 PM
Yes! We have 70mm DPs and 70mm IPs instock. The ABs and 76mm DPs and IPs are on the way.
Old May 20, 2004 | 07:23 PM
BatEvo's Avatar
...thanks man.
Old May 21, 2004 | 03:07 AM
simevo's Avatar
Titanium IP soon?
Old May 21, 2004 | 06:34 AM
BatEvo's Avatar
Is there much of a weight difference between an SS IP and a TI IP? The idea I’m working on right now would give me a cat back set-up that would weigh (total) less than the OEM IP does on its own.
Numbers are approximate (don’t have my notes handy);
OEM muff (26 lbs.) + OEM IP (11.7 lbs.) = 37.7 lbs.
Exhale AB (8 lbs.) + Exhale IP (7.6 lbs.) = 15.6 lbs.
BR AB (3.7 lbs.) + Exhale IP (7.6 lbs.) = 11.3 lbs.
Thanks
Rick
Old Jun 3, 2004 | 01:15 PM
BatEvo's Avatar
...Exhale 70mm non-res IP (7.6 lbs.) + New Exhale AB (6.25 lbs.) = 13.85 lbs., and thats our final answer.
Rick
Old Jun 4, 2004 | 10:45 AM
The 3 inch resonated IP's are now in stock.
The ABs are also now in stock.
Old Jun 4, 2004 | 02:39 PM
ttiscio's Avatar
Tyler,
Just talked to Pete on the phone and I am going to order my throttle body and DP prior to the IP (mainly because my P@ flash already includes those upgrades). I was planning on the 70mm IP, how much lowder is that than stock since I already have the AB pipe installed. Don't want to sound like a ricer . Wish I could come to the shop and see this stuff!
Old Jun 5, 2004 | 06:36 AM
Evo442's Avatar
I started with the Works throttle body and AB. That loudness was perfect in my opinion. Sounded good but not too loud.
I added the 70mm DP, and 76mm resonated IP and the system is significantly louder! I'm getting used to it, but is louder than what I had planned. Just my 2cents
Old Jun 5, 2004 | 10:16 AM
Originally Posted by ttiscio
Tyler,
Just talked to Pete on the phone and I am going to order my throttle body and DP prior to the IP (mainly because my P2 flash already includes those upgrades). I was planning on the 70mm IP, how much lowder is that than stock since I already have the AB pipe installed. Don't want to sound like a ricer . Wish I could come to the shop and see this stuff!
The 76mm resonated IP might be better for you.
It won't be as loud, and the sound will be deeper.
Old Jun 6, 2004 | 01:07 AM
Alias's Avatar
The 70mm NR IP is pretty loud in my opionion. I'll take Tyler's advise if I were you.
racer135
Dec 31, 2007 09:23 PM
