WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
MR wastegate
Old Sep 4, 2004 | 09:41 AM
TylerO@WORKS's Avatar
If you want the above pictured MR Recirc valve, we can get it for you, no problem.
Old Sep 4, 2004 | 10:04 AM
mitsuorder's Avatar
MR performs with such stock like feel, it's really a wonderful investment, personally I run a Hallman Pro RX with the MR diverter valve and experience zero taper
Old Sep 4, 2004 | 09:23 PM
RT's Avatar
RT
Tyler-
I just asked Pete this past Tuesday when I was up at the shop for one of the MR diverter valves so if you've found a source put my name on one and I'll call you on Monday.
Thanks
Rick
Old Sep 4, 2004 | 09:49 PM
MalibuJack's Avatar
Originally Posted by marksae
Does the MR use a different actuator than the 8? Forced Performance carries the 10.5cm^2 turbine housing with the newer style wastegate flapper. You can swap the turbine housing out and it'll be just like an MR!
http://linux.forcedperformance.net/m...ode=Lancer_EVO
Yes, the MR housing and the 10.5 housing have different flappers.. you can swap the housings on the turbos though since the MR Housing (I was told) is also a 10.5.. However due to the difference in the wastegate flapper desing, the O2 housing is also probably slightly different (At least they looked slightly different on the mating surfaces from the pictures I've seen..
I had access to purchase a few MR housings, but I had chose not to simply because of the uncertaintly of the O2 housing.. The truth is we won't really know until the cars become available and people start upgrading components. To be honest, I hope people keep their MR's stock and not tear into them like we have with the Evo's and RS's..
Old Sep 4, 2004 | 10:28 PM
stvbreal's Avatar
Originally Posted by chrisw
other than it's metel construction, it's not even close.
Close enough.
Old Sep 4, 2004 | 10:38 PM
Captain EVO's Avatar
Malibu Jack...
Why do you think people should not mess with the MR?
Old Sep 4, 2004 | 11:05 PM
marksae's Avatar
Hmm.. interesting. Do you think we could just port our current o2 housings to clear the different style flapper valve? It doesn't look like the valves protrude too much past the turbine housing.
Old Sep 4, 2004 | 11:09 PM
marksae's Avatar
Originally Posted by stvbreal
Close enough.
The 1g valve is similar in construction to the MR valve. However, the area of the MR valve is quite a bit bigger than the 1g valve. The 1g valve also needs to be crushed slightly to hold more boost.
