How to: adjust valve lash
Old Oct 7, 2013, 09:50 PM
  #136
CrAnSwIcK's Avatar
Originally Posted by Dnh143
I will be attempting this procedure tomorrow.
Just this part was my first initial worry: "Turn it CLOCKWISE by hand until the timing mark on the pulley lines up with the "T" on the timing cover. (Hope you guys with Joe's pulley put some kind of mark on yours before installing it, like I did)".
But since u said to go by the cam gear i will do that instead. Thanks again, i will keep it updated on how things go.
the crank has to be aligned too, like I said if your aftermarket pulley does not have a timing mark, you'll still need to visually verify TDC...pretty easy to tell, with a flashlight...
Old Oct 11, 2013, 02:04 PM
  #137
Jimbowned's Avatar
Originally Posted by Myszkewicz
I'd say it's still as quiet as when it was new.
The motor in an ES doesn't need valve lash adjustment, it has hydraulic lash adjusters that do it for you. Their oil holes can get clogged over time, making them louder. What kind of oil are you using in your car?
Hydraulic valve adjusters still need to be adjusted periodically. It is just a completely different process. Just ask anyone with a Chevy 350 engine.
anthonypazsd
134
Jan 19, 2024 11:48 PM
evolve_VIII
444
Dec 16, 2020 08:11 PM
Tw3NTy0n3
May 21, 2016 11:24 PM
Myszkewicz
Feb 8, 2007 05:21 PM
althemean
Apr 18, 2006 08:20 AM
Quick Reply: How to: adjust valve lash
